How Fast Should a Space Station Rotate to Mimic Earth's Gravity?
Becca93
A proposed space station includes living quarters in a circular ring 62.0 m in diameter. At what angular speed should the ring rotate so the occupants feel that they have the same weight as they do on Earth?
The attempt at a solution
I assumed that to do this problem, Fcp had to equal the force of gravity.
Fcp = Fg
mv^2 / r = mg
v^2 / r = g
v = √(rg)
v = √(62g)
v = 24.65
v = ωr
ω = v/r
ω = 24.65 / 62
ω = 0.398 rad/s
This isn't correct.
Does anyone have any advice on what to do differently? Any help would be greatly appreciated.
Fcp = Fg
mv^2 / r = mg
v^2 / r = g
v = √(rg)
v = √(62g)
v = 24.65
v = ωr
ω = v/r
ω = 24.65 / 62
ω = 0.398 rad/s
This isn't correct.
I don't see anything wrong with your physics. The problem may lie with your math. What value of g did you use? Using g = 9.81 N/kg, I get v = 24.66 m/s (to two decimal places).
I tried both, but when whittled down to the required three sigfigs, the answer is still 0.398 rad/s.
I'm at a loss as to what to do differently.
Oh. :redface:
62.0 m is the diameter of the space station, not its radius.
It helps if you read the problem carefully (and I apply this advice to you and me both!).
cepheid said:
Oh. :redface:
:redface: Do you ever have one of those moments where you just can't believe you mixed up something really simple?
Thank you very much for pointing that out. I feel a bit foolish, but I do have the right answer now.
