Rotational momentum (conservation problems)
The discussion focuses on calculating the rotational inertia and angular momentum of a rigid structure consisting of a circular hoop and a square made of four thin bars. The circular hoop has a radius (R) of 0.50 m and mass (m) of 2.0 kg, with a rotational period of 2.5 seconds. The rotational inertia for the hoop is given by the formula I = 1/2 MR^2, while the rotational inertia of the square requires the application of the parallel axis theorem. Participants emphasize the need to clarify the assumptions regarding the dimensions of the thin bars to accurately compute the moment of inertia.
  • Understanding of rotational inertia and angular momentum concepts
  • Familiarity with the parallel axis theorem
  • Knowledge of the moment of inertia formulas for various shapes
  • Basic understanding of rotational motion and angular velocity
  • Research the moment of inertia for a thin bar rotating about its end
  • Study the application of the parallel axis theorem in complex systems
  • Explore the derivation of rotational inertia formulas for composite shapes
  • Learn about angular momentum conservation in rotational systems
Students and educators in physics, mechanical engineers, and anyone interested in understanding rotational dynamics and calculating moments of inertia in complex structures.
thatguy14
1.A rigid structure consisting of a circular hoop (on the right) of Radius R and mass m, and a square (on the left) made of four thin bars, each of length R and mass m. The rigid structure rotates at a constant speed about a vertical axis, with a period of rotation of 2.5 s. Assuming R = 0.50m and m = 2.0 kg, calculate (a) the structures rotational inertia about the axis of rotation and (b) its angular momentum about that axis
There is a picture associated with the question but i can't upload it. Basically on the left is a square then right to the right of tht is a circle and inbetween the 2 there is a line drawn shoing the axis of rotation, the square is touching the circle.
2. Rotational inertia for the hoop = 1/2 MR^2
Parallel axis theorem = Icom + MH^2
I don't know how to find the rotational inertia of the square that is composed of 4 thin bars each of length R. The rotational inertia equation for the hoop was already given to us in a previous table in the book, but nothing for a thin rod rotating about its axis type of thing.
L = Iw w=(omega)
3. i couldn't do anything for this question as i couldn't find the rotational inertia of the square, I don't know how to.
I can't really picture what the system looks like, but you should be able to find the moment of inertia of the square as the combination of 4 bars (you should be able to look this up, or calculate it yourself) using the parallel axis theorem
hi i did look those up but the problem with it is that the questions usually tell you what to assume the thing is. It says thin bars not rods and it doesn't say to assume rods. So i asnt sure if there was something i was missing.
Also for all the moments of inertia of the rods that are parallel to the axis of rotation, there is no specified equation for the a thin rod with the axis of rotation down the rod; there's only perpendicular.
| || This is kind of what the diagram looks like
| || Except in this spot there is a circle that touches the axis of rotation
I don't know i that helps.
edit: seems it doesn't keep the formatting correclty. Ill try to get the image online so you can see it
So they don't give dimensions of the bars (other than length)? My guess is the moment of inertia will be the same as for a rod since the other dimensions are very small so they can be ignored. This also means that the moment of inertia around the rod's axis is basically 0, but you can still apply the parallel axis theorem.
16K
  • · Replies 17 ·
  • · Replies 22 ·
