How Far Can a Man Walk on a Plank Before It Tips Over?
The discussion revolves around a physics problem involving a man walking on a plank positioned on the edge of a building. The key challenge is determining how far the man can walk before the plank tips over, considering the forces and torques involved. The man has a mass of 70 kg and the plank has a mass of 210 kg, with the plank's center of mass directly over the edge. Participants express confusion about transitioning from static equilibrium to rotational dynamics once tipping occurs and the implications of torque about the pivot point. The conversation highlights the need to analyze the weight distribution of the plank and its effect on tipping.
einstein18
A man, of m = 70 kg, walks along a thin rigid plank, of M = 210 kg. The plank sits on the roof of a 10 story building and is placed so that its center of mass sits directly on the edge of the roof.
Where, along the plank, can the man move before the plank tips over the edge? Assume that friction is strong enough to keep the plank from moving horizontally.
Statics:
Y: (M+m)g=N(due to floor)
X: Not applicable
Torque=mgd=0
Rotational:
Torque=mgd=I*alpha
I am confused on how to relate the statics to the rotational part. I understand that as long as the plank doesn't fall the equilibrium equations remain true, however as soon as it does it is no longer true and the ratational torque becomes the reality. Now I don't understand how to create and equation that relates the change from one to the other as a function of how far the man walks. Can someone please help me out?
In order to tip, you just need an unbalanced torque about the pivot point (the edge of the roof, in this case).
This problem is a bit odd since the plank's center is right at the edge of the roof. Where does the weight of the plank act? Will it exert any torque about the pivot point?
  • · Replies 22 ·
