Runtime error 112 in Fortran Courant subroutine with Plato compiler
  • Topic: Fortran
  • Thread starter Thread starter 1994Bhaskar
    Code Fortran
4 replies · 3K views · last reply
1994Bhaskar
Hey everybody, I am a mechanical engineer and new to Fortran(I have decent experience in programming in C, Matlab and understand languages similar to them). However the Fortran programming structure is new to me. Hence I am facing problems debugging a Fortran code.
Here is the link of the code which I want to run.
http://www2.meteo.uni-bonn.de/forsch...rtran/coad1d.f
I am using a Plato Fortran Compiler.
It runs without showing error, but when I enter the values initially asked, the program stops mid-way showing an error:
Run-time Error
*** Error 112, Reference to undefined variable, array element or function result (/UNDEF)
COURANT - in file help.for at line 149 [+01de]
main - in file help.for at line 45 [+05dc]
So there is an error in the Courant subroutine or error in calling it. Again i am a little unfamiliar to fortran subroutines but is it possible for any of you to also check what the problem here is ?
As far as i could see the variables inside the subroutine were declared beforehand. And the logic looks correct.
Also is the declaration line 45 calling courant subroutine done correctly ?
Any help is appreciated. I have already received awesome help from you all here.
Mark44 said:
I can't get the link to open (HTTP 404 Not Found error). Please post the code directly in this page.
Mark44, here it is:(it is huge)
program coad1d
parameter (n=400)
implicit double precision (a-h,o-z)
common /const/ rq0,dlnr,scal,ax
common /cour/ c(n,n),ima(n,n)
common /grid/ g(n),r(n),e(n)
common /kern/ ck(n,n),ec(n,n)
dimension rri(n),eei(n)
data emin,pi,tmax/1.e-9,3.141592654,3600./
c dt : time step (input in sec)
c g : spectral mass distribution (mg/cm**3)
c e : droplet mass grid (mg)
c r : droplet radius grid (um)
c dlnr: constant grid distance of logarithmic grid
c rq0 : mode radius of initial distribution (input in um)
c xmw : total water content (input in g/m**3)
c xn0 : mean initial droplet mass (mg)
c xn1 : total initial droplet number concentration (1/cm^3)
c ax : growth factor for consecutive masses
c scal: scaling factor for calculation of ax, see below
c isw : collision kernel: 0 (long), 1 (hall), 2 (golovin)
c read input variables
print *,'enter dt,rq0,xmw,scal,isw'
read *,dt,rq0,xmw,scal,isw
rq0=rq0*1.e-04
xmw=xmw*1.d-3
xn0=4./3.*pi*1000.*exp(log(rq0)*3.)
xn1=xmw/xn0
dlnr=dlog(2.d0)/(3.*scal)
ax=2.d0**(1.0/scal)
c mass and radius grid
e(1)=emin*0.5*(ax+1.)
r(1)=1000.*dexp(dlog(3.*e(1)/(4.*pi))/3.)
do i=2,n
e(i)=ax*e(i-1)
r(i)=1000.*dexp(dlog(3.*e(i)/(4.*pi))/3.)
enddo
c initial mass distribution
x0=xn1/xn0
do i=1,n
x1=e(i)
g(i)=3.*x1*x1*x0*dexp(-x1/xn0)
enddo
c courant numbers
call courant
c kernel
call trkern (isw)
c output for plotting
do i=1,n
rri(i)=min(1.d38,r(i))
eei(i)=min(1.d38,e(i))
enddo
open (16,file='boplot00.out',status='old')
write (16,6100) rri,eei
6100 format (5e16.8)
c nt: number of iterations
nt=int(tmax/dt)
c multiply kernel with constant timestep and logarithmic grid distance
do i=1,n
do j=1,n
ck(i,j)=ck(i,j)*dt*dlnr
enddo
enddo
c time integration
tlmin=1.d-6
t=1.d-6
lmin=0
do ij=1,nt
t=t+dt
tlmin=tlmin+dt
c collision
call coad
if (tlmin.ge.60.) then
tlmin=tlmin-60.
lmin=lmin+1
print *,'time in minutes:',lmin
write (16,6100) t,g
c mass balance
x0=0.
x1=0.
do i=1,n
x0=x0+g(i)*dlnr
x1=max(x1,g(i))
if (dabs(x1-g(i)).lt.1.d-9) imax=i
enddo
print *,'mass ',x0,'max ',x1,'imax ',imax
endif
enddo
close (16)
stop 'stop coad1d'
end
subroutine coad
c collision subroutine, exponential approach
parameter (n=400)
data gmin /1.d-60/
c lower and upper integration limit i0,i1
do i=1,n-1
i0=i
if (g(i).gt.gmin) go to 2000
enddo
2000 continue
do i=n-1,1,-1
i1=i
if (g(i).gt.gmin) go to 2010
enddo
2010 continue
do i=i0,i1
do j=i,i1
k=ima(i,j)
kp=k+1
x0=ck(i,j)*g(i)*g(j)
x0=min(x0,g(i)*e(j))
if (j.ne.k) x0=min(x0,g(j)*e(i))
gsi=x0/e(j)
gsj=x0/e(i)
gsk=gsi+gsj
g(i)=g(i)-gsi
g(j)=g(j)-gsj
gk=g(k)+gsk
if (gk.gt.gmin) then
x1=dlog(g(kp)/gk+1.d-60)
flux=gsk/x1*(dexp(0.5*x1)-dexp(x1*(0.5-c(i,j))))
flux=min(flux,gk)
g(k)=gk-flux
g(kp)=g(kp)+flux
endif
enddo
enddo
return
end
subroutine courant
parameter (n=400)
do i=1,n
do j=i,n
x0=e(i)+e(j)
do k=j,n
if (e(k).ge.x0.and.e(k-1).lt.x0) then
if (c(i,j).lt.1.-1.d-08) then
kk=k-1
c(i,j)=dlog(x0/e(k-1))/(3.d0*dlnr)
else
c(i,j)=0.
kk=k
endif
ima(i,j)=min(n-1,kk)
go to 2000
endif
enddo
2000 continue
c(j,i)=c(i,j)
ima(j,i)=ima(i,j)
enddo
enddo
return
end
subroutine trkern (isw)
parameter (n=400)
common /veloc/ winf(n),rr(n)
dimension cck(n,n)
data pi/3.141592654/
c terminal velocity
call fallg
if (isw.eq.0) then
c long kernel
do j=1,n
do i=1,j
if(r(j).le.50.) then
effi=4.5d-4*r(j)*r(j)*
& (1.d0-3.d0/(max(3.d0,dble(r(i)))+1.d-2))
else
effi=1.d0
endif
cck(j,i)=pi*(rr(j)+rr(i))*(rr(j)+rr(i))*effi*
& abs(winf(j)-winf(i))
cck(i,j)=cck(j,i)
enddo
enddo
elseif (isw.eq.1) then
c hall kernel
call effic
do j=1,n
do i=1,j
cck(j,i)=pi*(rr(j)+rr(i))*(rr(j)+rr(i))*ec(j,i)*
cck(i,j)=cck(j,i)
enddo
enddo
else
c golovin kernel
do j=1,n
do i=1,j
cck(j,i)=1.5*(e(j)+e(i))
cck(i,j)=cck(j,i)
enddo
enddo
endif
c two-dimensional linear interpolation of kernel
do i=1,n
do j=1,n
jm=max0(j-1,1)
im=max0(i-1,1)
jp=min0(j+1,n)
ip=min0(i+1,n)
ck(i,j)=0.125*(cck(i,jm)+cck(im,j)+cck(ip,j)+cck(i,jp))
& +.5*cck(i,j)
if (i.eq.j) ck(i,j)=0.5*ck(i,j)
enddo
enddo
return
end
subroutine fallg
c terminal velocity of falling drops
parameter (n=400)
dimension b(7),c(6),rat(20),r0(15),ecoll(15,20)
data b /-0.318657e1,0.992696,-0.153193e-2,-0.987059e-3,
& -0.578878e-3,0.855176e-4,-0.327815e-5/
data c /-0.500015e1,0.523778e1,-0.204914e1,0.475294,-0.542819e-1,
& 0.238449e-2/
data pi /3.141592654/
eta=1.818e-4
xlamb=6.62e-6
rhow=1.
rhoa=1.225e-3
grav=980.665
cunh=1.257*xlamb
t0=273.15
sigma=76.1-0.155*(293.15-t0)
stok=2.*grav*(rhow-rhoa)/(9.*eta)
stb=32.*rhoa*(rhow-rhoa)*grav/(3.*eta*eta)
phy=sigma*sigma*sigma*rhoa*rhoa/((eta**4)*grav*(rhow-rhoa))
py=phy**(1./6.)
c rr: radius in cm-units
do j=1,n
rr(j)=r(j)*1.e-4
enddo
do j=1,n
if (rr(j).le.1.e-3) then
winf(j)=stok*(rr(j)*rr(j)+cunh*rr(j))
elseif (rr(j).gt.1.e-3.and.rr(j).le.5.35e-2) then
x=log(stb*rr(j)*rr(j)*rr(j))
y=0.
do i=1,7
y=y+b(i)*(x**(i-1))
enddo
xrey=(1.+cunh/rr(j))*exp(y)
winf(j)=xrey*eta/(2.*rhoa*rr(j))
elseif (rr(j).gt.5.35e-2) then
bond=grav*(rhow-rhoa)*rr(j)*rr(j)/sigma
if (rr(j).gt.0.35) bond=grav*(rhow-rhoa)*0.35*0.35/sigma
x=log(16.*bond*py/3.)
y=0.
do i=1,6
y=y+c(i)*(x**(i-1))
enddo
xrey=py*exp(y)
if (rr(j).gt.0.35) winf(j)=xrey*eta/(2.*rhoa*0.35)
endif
enddo
return
end
subroutine effic
c collision efficiencies of hall kernel
parameter (n=400)
dimension rat(21),r0(15),ecoll(15,21)
data r0 /6.,8.,10.,15.,20.,25.,30.,40.,50.,
& 60.,70.,100.,150.,200.,300./
data rat /0.,0.05,0.1,0.15,0.2,0.25,0.3,0.35,0.4,0.45,0.5,
& 0.55,0.6,0.65,0.7,0.75,0.8,0.85,0.9,0.95,1.0/
data ecoll /
& 0.001,0.001,0.001,0.001,0.001,0.001,0.001,0.001,0.001,0.001
& ,0.001,0.001,0.001,0.001,0.001,0.003,0.003,0.003,0.004,0.005
& ,0.005,0.005,0.010,0.100,0.050,0.200,0.500,0.770,0.870,0.970
& ,0.007,0.007,0.007,0.008,0.009,0.010,0.010,0.070,0.400,0.430
& ,0.580,0.790,0.930,0.960,1.000,0.009,0.009,0.009,0.012,0.015
& ,0.010,0.020,0.280,0.600,0.640,0.750,0.910,0.970,0.980,1.000
& ,0.014,0.014,0.014,0.015,0.016,0.030,0.060,0.500,0.700,0.770
& ,0.840,0.950,0.970,1.000,1.000,0.017,0.017,0.017,0.020,0.022
& ,0.060,0.100,0.620,0.780,0.840,0.880,0.950,1.000,1.000,1.000
& ,0.030,0.030,0.024,0.022,0.032,0.062,0.200,0.680,0.830,0.870
& ,0.900,0.950,1.000,1.000,1.000,0.025,0.025,0.025,0.036,0.043
& ,0.130,0.270,0.740,0.860,0.890,0.920,1.000,1.000,1.000,1.000
& ,0.027,0.027,0.027,0.040,0.052,0.200,0.400,0.780,0.880,0.900
& ,0.940,1.000,1.000,1.000,1.000,0.030,0.030,0.030,0.047,0.064
& ,0.250,0.500,0.800,0.900,0.910,0.950,1.000,1.000,1.000,1.000
& ,0.040,0.040,0.033,0.037,0.068,0.240,0.550,0.800,0.900,0.910
& ,0.950,1.000,1.000,1.000,1.000,0.035,0.035,0.035,0.055,0.079
& ,0.290,0.580,0.800,0.900,0.910,0.950,1.000,1.000,1.000,1.000
& ,0.037,0.037,0.037,0.062,0.082,0.290,0.590,0.780,0.900,0.910
& ,0.950,1.000,1.000,1.000,1.000,0.037,0.037,0.037,0.060,0.080
& ,0.290,0.580,0.770,0.890,0.910,0.950,1.000,1.000,1.000,1.000
& ,0.037,0.037,0.037,0.041,0.075,0.250,0.540,0.760,0.880,0.920
& ,0.950,1.000,1.000,1.000,1.000,0.037,0.037,0.037,0.052,0.067
& ,0.250,0.510,0.770,0.880,0.930,0.970,1.000,1.000,1.000,1.000
& ,0.037,0.037,0.037,0.047,0.057,0.250,0.490,0.770,0.890,0.950
& ,1.000,1.000,1.000,1.000,1.000,0.036,0.036,0.036,0.042,0.048
& ,0.230,0.470,0.780,0.920,1.000,1.020,1.020,1.020,1.020,1.020
& ,0.040,0.040,0.035,0.033,0.040,0.112,0.450,0.790,1.010,1.030
& ,1.040,1.040,1.040,1.040,1.040,0.033,0.033,0.033,0.033,0.033
& ,0.119,0.470,0.950,1.300,1.700,2.300,2.300,2.300,2.300,2.300
& ,0.027,0.027,0.027,0.027,0.027,0.125,0.520,1.400,2.300,3.000
& ,4.000,4.000,4.000,4.000,4.000/
c two-dimensional linear interpolation of the collision efficiency
do j=1,n
do i=1,j
do k=2,15
if (r(j).le.r0(k).and.r(j).ge.r0(k-1)) then
ir=k
elseif (r(j).gt.r0(15)) then
ir=16
elseif (r(j).lt.r0(1)) then
ir=1
endif
enddo
rq=r(i)/r(j)
do kk=2,21
if (rq.le.rat(kk).and.rq.gt.rat(kk-1)) iq=kk
enddo
if (ir.lt.16) then
if (ir.ge.2) then
p=(r(j)-r0(ir-1))/(r0(ir)-r0(ir-1))
q=(rq-rat(iq-1))/(rat(iq)-rat(iq-1))
ec(j,i)=(1.-p)*(1.-q)*ecoll(ir-1,iq-1)+
& p*(1.-q)*ecoll(ir,iq-1)+
& q*(1.-p)*ecoll(ir-1,iq)+
& p*q*ecoll(ir,iq)
else
ec(j,i)=(1.-q)*ecoll(1,iq-1)+q*ecoll(1,iq)
endif
else
ek=(1.-q)*ecoll(15,iq-1)+q*ecoll(15,iq)
ec(j,i)=min(ek,1.d0)
endif
ec(i,j)=ec(j,i)
if (ec(i,j).lt.1.e-20) stop 99
enddo
enddo
return
end
Isn't this the same question you asked at the end of your other thread? If so, I posted what I think might be wrong in that thread.
