Undergrad Solve Scalar Product Problem in Set R of Functions [0,1]
The discussion revolves around defining a scalar product for functions in the set R, which consists of functions defined on the interval [0,1] that are nonzero at countably many points. The scalar product is initially defined as a sum over pairs of points where the functions are nonzero, but concerns arise regarding convergence and the ordering of these points. The participants explore the implications of different orderings on the scalar product's properties, particularly focusing on the challenge of proving linearity in the scalar product. They propose a revised definition of the scalar product that considers the union of nonzero points from both functions, suggesting that absolute convergence could resolve the issues encountered. Ultimately, they conclude that as long as the sum is absolutely convergent, the scalar product can be appropriately defined, aligning with established mathematical principles.
Gear300
Alright, so we ran into a peculiarity in answering this question.
Let R be the set of all functions f defined on the interval [0,1] such that -
(1) f(t) is nonzero at no more than countably many points t1, t2, . . .
(2) Σi = 1 to ∞ f2(ti) < ∞ .
Define addition of elements and multiplication of elements by scalars in the ordinary way, i.e., (f + g)(t) = f(t) + g(t), (αf)(t) = αf(t). If f and g are two elements of R, nonzero only at the points t1, t2, . . . and t'1, t'2, . . . respectively, define the scalar product of f and g as
(3) (f,g) = Σi,j = 1 to ∞ f(ti)g(t'j) .
Prove that this scalar product makes R into a Euclidean space.
By the looks of it, (3) is not referring to a sum across all pairs (i,j), since that may induce (absolute) convergence issues for certain elements in the set, where it might not be possible for them to have a finite norm. So we figured that the sum (3) is such that i and j run in parallel across Z+, like it would be in l2.
The peculiarity we found next is in the ordering of the countable domain of points with non-zero image. It may not be well-ordered for some functions, and even if you were to assume only well-ordered domains, there can be several different countable orderings (given that the sums of functions are included). One possibility we considered is if f has smaller ordering than g, we can generalize the sum (3) so that it only goes up to the ordering of f (like we would if f had a finite domain and g had a countable domain). But even so, the list of plausible orderings goes a long way in [0,1], and then there is a problem with resolving one of the properties of the scalar product:
(iv) (f , g+h) = (f , g) + (f , h)
Typically, proving (iv) would involve showing that (f , g+h) remains absolutely convergent. But the problem is how to consider the domain of g+h in the left expression as opposed to the individual domains of g and h in the right expression. In any case, we're stuck.
Mathematics news on Phys.org
Where does the question come from? The scalar product doesn't seem to make sense.
What I could imagine is $$(f,g) = \sum_{k=1}^{\infty} f(s_k) g(s_k)$$ where the sk are the union of ti and t'i. Or the intersection, doesn't make a difference here.
So for completion, we have managed to prune the problem statement to something doable. Altogether, it works when considering mfb's statement of the scalar product -
- which is the intuitive way of looking that things, since that is how the scalar product in C2[a,b] behaves. The general idea is that -
- is an instance of absolute convergence, where absolute convergence implies unconditional convergence. Then by http://math.uga.edu/%7Epete/3100supp.pdf, Chapter 2 . Section 9 . pg 89 . Theorem 2.52:
For a : NR an ordinary sequence and A ∈ R, the following are equivalent:
i. The unordered sum Σn ∈ Z+ an is convergent, with sum A.
ii. The series Σn = 0 to ∞ an is unconditionally convergent, with sum A.
So given any countable (un)ordering of points of non-zero image, so long as there exists a reordering ω that is absolutely convergent, then everything should fit together.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 36 ·
  • · Replies 26 ·
