How fast will 120 psi travel through a 3 inch tube in mph?
The speed at which air travels through a 3-inch tube under 120 PSI is not a straightforward calculation, as pressure alone does not determine flow velocity. A pressure gradient, such as a difference between 120 PSI and 100 PSI, is necessary for flow to occur. The pressure gradient travels at approximately sonic speeds, but the actual flow speed will depend on the configuration of the system, including the size of the reservoir and valve. For accurate estimates, consider using a large reservoir and appropriate valve sizes to minimize delays in pressure equalization.
  • Understanding of pressure dynamics and flow principles
  • Knowledge of pressure gradient calculations
  • Familiarity with pneumatic systems and components
  • Basic concepts of fluid dynamics
  • Research "Calculating flow velocity in pneumatic systems"
  • Learn about "Pressure gradient effects on fluid dynamics"
  • Explore "Sonic speed in gases and its implications"
  • Investigate "Designing efficient pneumatic systems with reservoirs"
Engineers, physicists, and hobbyists working with pneumatic systems, particularly those interested in optimizing flow dynamics and pressure management in tubes and valves.
Joey Bradshaw
I need help finding out how fast 120 psi will travel though a 3 inch tube in mph. My partners are counting on me and thanks to anyone that can help me.
What do you know and what part are you having trouble with?
When you say 120 PSI you are talking about a pressure. Flow is a different variable. For instance you could say I have a tube with 120 PSI in it, say 3 inch diameter and 4 feet long and it is enclosed so that is the total volume and we open a valve quickly to another tube say also 3 inch diameter and 4 feet long and at a vacuum level of 1 millitorr, you could do a speed calculation but just a tube with 120 PSI in it does not indicate flow so the speed would be zero there.
Also, for there to be a flow, there has to be a place with say 120 PSI and another place with say 100PSI, that would flow from high to low PSI and the difference of 20 PSI would be the variable to use to calculate air velocity, or water or oil, whatever.
"Flow" may not be the proper term, although the air in the pipe does move as it is compressed. Maybe "pressure gradient travel" would be a better term. Not a big deal in any case. First, be aware that pressure gradients travel at roughly sonic speeds so the time intervals will be quite short. And there will be a slight error due to the time it takes for enough air at 120 PSI to fill into the pipe to pressure it up. This can be minimized by using a relatively large reservoir and valve vs. the diameter of the pipe. For example, 1/2" tubing and a 2" ball valve on a 60 gallon reservoir. That's all I can come up with right now.
Potato gun?
It's probably going to depend on details of your valve and container, but for a ballpark estimate, you could start with the speed of sound.
  • · Replies 16 ·
  • · Replies 16 ·
