Schrodinger equation graph help
The discussion revolves around interpreting an anomaly in a graph related to the Schrödinger equation, presented in the context of an alternate reality game (ARG) called "Find the Lost Ring." Participants explore the implications of the graph, its connection to quantum mechanics, and historical events, particularly focusing on the year 1815.
  • One participant requests help from knowledgeable physicists to interpret an anomaly in a Schrödinger equation graph associated with an ARG.
  • Another participant speculates that the graph might relate to quantum tunneling and questions the significance of the year 1815.
  • A participant suggests that the graph describes how wavelength evolves over time and prompts others to consider significant events from 1815.
  • One contributor explains that the Schrödinger equation can plot a probability distribution for a system's state, particularly in relation to the spectral lines of hydrogen, but expresses uncertainty about the graph's specific application.
  • Another participant posits that the graph may represent parallel universes, suggesting that the upper line indicates a sum of universes, with events triggering the destruction of some to allow for new ones.
  • A participant expresses difficulty in understanding the graph without knowing what the y-axis represents.
Participants express various hypotheses regarding the graph's meaning and its connection to quantum physics, but no consensus is reached on its interpretation or the significance of the anomaly.
Participants mention the need for clarity on the y-axis of the graph to better understand its implications. There are also references to historical events and speculative connections to quantum theory that remain unresolved.
Cnslr2000
I hope I'm not offending anyone here by posting a request for some help here. We are in need of a knowledgeable physicist who can interpret an anomoly in a Schrödinger equation graph. This is for an online alternate reality game ("ARG") called Find the Lost Ring.
The graph can be found here:
http://164.109.150.213/index.html
After going to the site, you'll see a globe with tiny dots. Clicking anywhere on the page and begin typing "RUN GRAPH" will show what I've been told is a Schrödinger equation and a graph. Typing "CLOSE" will then close the text inputter and the graph with a slider appears at the bottom. Waving the cursor over the left side of the graph will produce a tool to close up on the graph. Sliding it left and right moves along the date axis. Around 1815, an anomoly occurs where the lines drop significantly and then resume in a wave pattern.
We need a physicist to help interpret this graph. Any help would be greatly appreciated. Feel free to email me.
Is this one of the google games where you have to guess some obscure codeword?
I don't know, maybe it has something to do with quantum tunneling, maybe you have to look for a tunnel built in 1815?
But that would be too easy right?
No, it's not a google game.
It's associated with the upcoming China Olympics and has numerous international players participating in many different aspects.
You can read about it here:
http://olympics.wikibruce.com/Home
But I warn you. Once you start looking into it, it can become somewhat addicting.
I came here because I'm particularly intringued by the graph and what Schrödinger has to do with it.
Well, this looks like the graph is describing how wavelength [tex]\lambda[/tex] evolves with time (years).
So, what significant event happened in 1815?
Well the Schrödinger equation enables you to plot a probability distribution to determine what state a system is in. For example it along with other approaches can be used to determine the spectral lines of hydrogen. I would guess though that this is trying to map the probability cloud of an electron. But why they are using the Schrödinger equation to do so I have no idea? i suppose it's pretty much like a big graph of a probability that the electron will be in any position at any given time in a hydrogen atom. So it depends on the quantization of the electrons in a hydrogen atom. Which are according to quantum theory most likely at certain values, and then vanishingly likely the further you get from that "position" data. That's I'm afraid the limit of my extremely limited knowledge.
http://www.aureas.org/rams/rams15Das4.gif
http://www.hy2.gr/reference/images/clip_image025.jpg
Here's a couple of pictures of what you would get eventually if you ran the SE for hydrogen.
As you can see certain quantizations are favoured, however it can be misleading to assume those closer to the atom are necessarily more favoured, as we must take into account the dimensions of the picture.
By the way I couldn't get the graph up so I have no idea what the graph looks like.
Even more interesting is if you look at the graph in 2008 a closeup reveals the lines actually move backwards.
Many playing the game have surmized that each line represents a collection parallel universes. Some of the other hints have revealed that the upper line (white) is a sum of the number of universes that each line represents and that when the upper limit (1x10^11) of universes is reached, an event (a rapid continental change) triggers the destruction of many universes so there is room to "grow" more universes (from multiple decision making).
I know this is beyond the scope of this forum, but I thought many of you might like to get involved as it clearly has some quantum physics involved.
You can go to one of these forums to discuss it if you please:
http://forums.findthelostring.com/message/3677#3677
http://forums.unfiction.com/forums/viewtopic.php?p=505974#505974
http://forums.unfiction.com/forums/viewtopic.php?t=24732&start=435
Thanks so much for all the help here.
Ah right I finally managed to get it to run. Nope no idea what it's doing other than the suggestions already made, but then you'd have to know what the y-axis represents to have any idea what it is meant to be I think.
  • · Replies 21 ·
  • · Replies 27 ·
  • · Replies 140 ·
  • · Replies 19 ·
11K
