Schrodinger Equation in a representation
7 replies · 3K views · last reply
youngurlee
The general evolution of a ket [itex]|\psi\rangle[/itex] is according to
[itex]-i\hbar\frac{d}{dt}|\psi\rangle=H|\psi\rangle[/itex]
without specifying a representation.
From this equation, how can you simply get a equation in a certain representation [itex]F[/itex] as below:
[itex]-i\hbar\frac{\partial}{\partial t}\langle f|\psi\rangle=\langle f|H|\psi\rangle[/itex] ?
doesn't it need the validity of
[tex]\langle f|\frac{d}{dt}|\psi\rangle=\frac{∂}{∂t}\langle f|\psi\rangle[/tex]
does this always hold for any ket and bra in a Hilbert space and its dual space?
As long as f is time independent, yes. This is true in the Schroedinger picture for example, where f can be x or p_x and as operators these are time independent.
thank you for your reply, but I really think some condition is required.
for example, look upon [itex]\langle f|[/itex] (independent of [itex]t[/itex]) as a eigenbra of [itex]F[/itex] whose eigenbras are continuous in [itex]f[/itex]. and [itex]\langle f|[/itex] acts on [itex]|\psi\rangle[/itex] as an linear functional.
that is:
[itex]\langle f|\psi\rangle=\psi (f,t)=\int^{+\infty}_{-\infty}\phi^*(x,f)\psi (x,t)dx[/itex]
so, [itex]\langle f|\frac{d}{dt}|\psi\rangle=\frac{∂}{∂t}\langle f|\psi\rangle[/itex] in this case means:
[itex]\int^{+\infty}_{-\infty}\phi^*(x,f)\frac{\partial}{\partial t}\psi (x,t)dx=\frac{\partial}{\partial t}\int^{+\infty}_{-\infty}\phi^*(x,f)\psi (x,t)dx[/itex]
I mean, doesn't this equation (exchange of derivative and improper integral) require some condition, such as the uniform convergence of the improper integral[itex]\int^{+\infty}_{-\infty}[/itex]?
youngurlee said:
[...] but I really think some condition is required. [...]
One way to deal with this more rigorously is to work in the context of so-called "rigged Hilbert space" (Gel'fand triples) -- if you're not familiar with these terms, think "generalized functions" or "distributions". Derivatives are then typically interpreted as some kind of "weak derivative".
http://en.wikipedia.org/wiki/Weak_derivative
The integral here is a Lebesgue integral, not a Riemann integral, so I think interchange of derivative and integral is allowed.
lugita15, I know little about Lebesgue integral.
Be it a Lebesgue integral, interchange of derivative and integral is always allowed ?
I read somewhere that Lebesgue integral is a generalization of Riemann integral, then if the interchange in Riemann integral does not hold for a certain integral, will it hold in Lebesgue integral ?
