Complex-Valued Solutions of Second-Order Linear Equations
The discussion focuses on proving that if y(t) is a complex-valued solution of the second-order linear equation y'' + py' + qy = 0, where p and q are real numbers, then both the real part yre(t) and the imaginary part yim(t) are also solutions. The approach involves substituting y(t) = yre(t) + iyim(t) into the differential equation and separating the real and imaginary components. It is established that both parts must independently satisfy the equation, leading to y''re + py're + qyre = 0 and i(y''im + py'im + qyim) = 0. The conclusion emphasizes that the linear combination of particular solutions remains a valid solution, confirming the general solution form y(t) = yre(t) + iyim(t). This demonstrates the relationship between complex solutions and their real-valued counterparts in second-order linear equations.
Dusty912
Suppose y(t) is a complex-valued solution of y'' +py' + qy=0 where p and q are real numbers. Show that if y(t)=yre(t) + iyim(t), where yre(t) and yim(t) are real valued, then both yre(t) and yim(t) are solutions of the second-order equation.
We can use the idea that a complex numbers is zero as long as it's real and imaginary parts are equal to zero.
I do not have an attempt at this solution. I do not know where to begin.
thanks for your help :)
Begin by plugging y(t)=yre(t) + iyim(t) into your DE and see what happens.
then I would get y''re(t) + py're(t) +qyre(t) +y''im(t) +py'im(t) +qyim(t)=0
so the real part would add up too zero and the imaginary part would add up to zero.
would this be correct?
Where'd the factor of ##i## go?
oops so it would be y''re(t) + py're(t) +qyre(t) +iy''im(t) +ipy'im(t) +iqyim(t)=0
lets take yre as a solution, y''re + py're+qyre=0
then take yim as a solution, y''im+py'im +qyim=0
the multiply with i both sides of the 2nd eqn,
i(y''im+py'im +qyim)=0
linear combination of particular solutions isalso a solution,
general solution y(t)=yre(t) + i yim(t)
  • · Replies 24 ·
