Seperation for third order maxima for two wavelengths - help please
tg22542
A grating has 1070 lines per centimetre, and a flat screen is perpendicular to the ray that makes the central peak of the diffraction pattern. The screen is 3.20 m from the grating. If light of two wavelengths, 630 nm and 705 nm, passes through the grating, what is the separation on the screen between the third-order maxima for the two wavelengths?
mλ = dsinΘ
d = 1/1070 = .000935 * 10 000 000 = 9345.79nm
λ1 = Θ1 = sin^-1(3*705 / 9345.79) = 13.0796°
λ2 = Θ2 = sin^-1(3*630 / 9345.79) = 11.6674°
[3.2tan(13.0796°)] - [3.2tan(11.6674)] = .082673 * 1000 = 82.67 nm
My answer is incorrect, can anyone see where I'm going wrong here?
Also, where I multiplied my numerator by 3 above, I did that due to the third order maxima, is that correct? I was impatient and also tried multiplying it by 2 instead, also incorrect.
Please help me out here.
Check your arithmetic.
oops.
Then shouldn't using (1/107) * 10000000 as my new value be right?
It's still wrong.
It's still wrong.
Two things:
(1) That should be (.1/1070)
(2) 1 nm = 10^-9 m
I still got it wrong.
I'll show you once more what I'm doing nowd = .1/1070 = .000093 * 10 000 000 = 934.579nm
λ1 = Θ1 = sin^-1(3*705 / 934.579) = x1°
λ2 = Θ2 = sin^-1(3*630 / 934.579) = x2°
[3.2tan(x1°)] - [3.2tan(x2)] = z
z*1000 = ansstill wrong thoughWhere exactly do i need to make changes, and what are those changes? I have 6 tries left.
.1/1070 = 0.0000934579 m. So far, so good.
Why do you then multiply by 10 000 000? Instead, multiply by 109.
im doing all of this and still getting it wrong
Post each step, just like you did before.
Most previous try:
d = .1/1070 = .000093 * 10^9 = 93457.9 nm
λ1 = Θ1 = sin^-1(3*705 / 93457.9) = 1.297°
λ2 = Θ2 = sin^-1(3*630 / 93457.9) = 1.159°
[3.2tan(1.297)] - [3.2tan(1.159)]
= .0077 nm
tg22542 said:
Most previous try:
= .0077 nm
That answer in is meters, not nm. What units do they want the answer in? mm makes sense.
Well the units don't matter, hold on I will convert it and give it a try!
7.7mm didn't work
tg22542 said:
7.7mm didn't work
I don't see an obvious error, unless it's just a significant figures issues. Often those systems want 3 sig figs no matter what.
Otherwise I will look at this more carefully later and see if there's another error that I missed.
Sounds great. Thank you very much for your help this far.
I don't see any errors in the calculation.
Did you try using 3 sig figs in your response? (I assume this is some online system, not a textbook problem, right?)
If all else fails, it might help to take a screenshot of the question so that we can check that there's no ambiguity. (Though it seems pretty clear.)
I did try 3 sig figs.. still wrong. In my angle calculation (second step), I multiplied each wavelength by 3, is that correct?
Sure.
13K
10K
  • · Replies 16 ·
