Proof of Sequence Convergence: 0<r<1 and 0<x_n<Cr^n?
blinktx411
Let X=(x_n) be a sequence of strictly positive numbers such that \lim(x_{n+1}/x_n)&lt;1. Show for some 0&lt;r&lt;1, and for some C&gt;0, 0&lt;x_n&lt;Cr^n
Let \lim(x_{n+1}/x_n)=x&lt;1
By definition of the limit, \lim(x_{n+1}/x_n)=x \Rightarrow \forall \epsilon&gt;0 there exists \: K(\epsilon) such that . \: \forall n&gt;K(\epsilon)
|\frac{x_{n+1}}{x_n}-x|&lt;\epsilon
Since i can pick any epsilon, let epsilon be such that \epsilon + x = r &lt;1. Also, I know that since this is a positive sequence, \frac{x_{n+1}}{x_n}&gt;0. Therefore, for large enough n,
0&lt;\frac{x_{n+1}}{x_n}&lt;r&lt;1.
From here I am not sure where to go, any hints would be much appreciated! I cannot find out what this tells me about $x_n$
For large enough n you also have the following:
\frac{x_{n+k}}{x_n} = \frac{x_{n+1}}{x_n} \frac{x_{n+2}}{x_{n+1}} \cdots \frac{x_{n+k}}{x_{n+k-1}} &lt; r^k
Can I let x_n=C and therefore say the sequence x_{n+k}&lt;Cr^k? If so then n would fixed and k would be the index, correct? Thanks for the speedy response!
You're not quite there yet.
First note that you need
x_{n} &lt; C r^n
not
x_{n+k} &lt; Cr^k
Also, it needs to be true for EVERY n, not just sufficiently large n.
First let's introduce some notation. It is easier to discuss if we give this "sufficiently large" n a name, say N. For all n \geq N,
0 &lt; \frac{x_{n+1}}{x_n} &lt; r &lt; 1
which yields
x_{N+k} &lt; r^k x_N
for all k \geq 0.
I can get the index and exponent to agree by writing, equivalently,
x_{N+k} &lt; r^{N+k} (x_N r^{-N})
Then if I set C_1 = x_N r^{-N} I get
x_{N+k} &lt; C_1 r^{N+k}
which looks pretty promising. However, this C_1 may not be large enough to work for ALL n, i.e. it may not be true that
x_n &lt; C_1 r^n
for all n &lt; N.
But note that there are only finitely many x_n with n &lt; N. Can you use that fact to find a C that does work for all n?
So, for every j&lt;N, Let M_j be such that x_j&lt;M_jr^j (there exists such an M by the archimedean property). Now, if I take C=\sup\{M_j,C_1| j\in\mathbb{N},j&lt;N\}, that should do the job since there are only finitely many M's, correct?
Looks good to me. You can even call it "max" instead of "sup" since there are only N+1 numbers under consideration.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
