Series: What do I have the right to do?
  • Thread starter Thread starter duffman
    Series
10 replies · 2K views
duffman
I have to say if the series converge or diverge.
[tex]\infty[/tex]
[tex]\sum[/tex] LN(n[tex]/2n+5[/tex])
n=1
I found this series to be divergent. However, I don't know if the way I proceeded is correct.
I first separated the ln into two lns ( ln(n) - ln(2n+5 ). Then, I used it as a power of e to remove the lns, thus being left with -n -5. I then went for the limit divergence test, and it ended up diverging.
Do I have the right to proceed that way?
Are you summing ln(n/(2n+5))? If so, the first think you should check is whether the sequence ln(n/(2n+5)) approaches 0 as n->infinity. Does it?
Well ...
ln(n) - ln(2n+5) equals infinity minus infinity, which is an undetermined form. from there I'm just lost. I remembered about the e trick, but I'm not certain if I can use it in the case of series. This is probably very basic stuff but I haven't done it in ages... I totally lost my "instinct". I don't want to waste anyone's time...
Whats the limit of n/(2n+5) as n->infinity? Don't split it first.
That would be infinity on infinity... If I use L'Hopital's rule, that would give me 1/2.
You don't need to l'hospital's. That's killing a cockroach with a nuke. Divide top and bottom by n.
Hahaha. Alright. Resulting in 1/(2+5/n) and 5/n goes to zero.
That gives us the limit of a constant, which would then be ln(1/2) ?
Correct. And if you add up an infinite number of those ln(1/2)'s, what do you get?
So since the limit does not equal zero, the series is divergent.
That is so correct.
