Unveiling the Mystery of Thermostat 'Setting': Tips from an Electrical Expert
  • Thread starter Thread starter rohanprabhu
Setting a thermostat involves adjusting a bi-metallic strip, which can be finely calibrated using an adjustable screw. This strip expands with temperature changes, altering the mechanical position of an electrical contact to achieve specific temperature settings. For precise adjustments, one can test the thermostat in hot water and tweak the screw until it activates at the desired temperature. Commercial thermostats are often calibrated for accuracy, allowing for reliable temperature control. If the repair was solely a thermostat adjustment, it may not have addressed any underlying issues with the geyser.
rohanprabhu
Recently, my hot water geyser wasn't heating water.. so I called up the electrical guy and he came to repair it. I don't know what he did, since I wasn't home when he repaired it.. my mom said that he 'set' the thermostat at 65 deg. C.
How exactly do you 'set' a thermostat? Since it's just a bi-metallic strip, how can u so finely graduate it to such a setting? and it's not just with the geyser.. even home heaters and ACs use similar kind of thermostats. How are they 'set' to certain temperatures?
Bimetal strips normally have an adjustable screw that makes the other side of the contact. You could - if you were bothered - set it by putting it in a pan of hot water at the right temperature and adusting the screw until it just closed.
I imagine commercial ones are (sort-of) calbrated
Mechanical thermostats expand with temperature, changing a mechanical position of an electrical contact. The mechanical position of the contact is pretty well definied by the temperature that is being sensed. So by rotating or moving the whole assembly, you can bias the fixture to make electrical contact at lower or higher temperatures. If you just take the cover off of any thermostatic control, its operation is pretty intuitive.
See if this wikipedia article helps some:
http://en.wikipedia.org/wiki/Thermostat
The reason you can get fine adjustment over the thermostat is that the bimetallic strip is coiled, which magnifies the motion created by a change in temperature.
Now if all this repair guy did was set your thermostat, he didn't really repair anything.
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
16K
  • · Replies 25 ·
42K
  • · Replies 19 ·
  • · Replies 17 ·
