Setting Pressure on Relief valves on Water Cooled Panels
The discussion revolves around the installation of relief valves on water-cooled panels used in electric arc furnaces within the steel industry. Participants explore the appropriate pressure settings for these valves, considering the high temperatures of molten metal and the potential for water to convert to steam, which raises safety concerns.
  • One participant inquires about the necessary pressure settings for relief valves, emphasizing the risk of water turning to steam if the panels leak.
  • Another participant suggests that additional information is needed, such as the heat dissipation method, pressure ratings, pump specifications, and pipe dimensions to estimate flow and pressure drop.
  • A different participant highlights the importance of knowing the specifications and safe operating pressures of the panels, as well as the capacity of the Pressure Relief Valve (PRV) to handle emergency situations.
  • Concerns are raised about the dangers of steam explosions and the need for proper engineering and safety measures, urging the original poster to consult with safety officers or professionals.
  • One participant expresses strong caution against attempting to engineer solutions through an online forum, recommending consultation with a vendor or a registered professional engineer.
Participants express significant concern regarding safety and the complexity of the engineering involved, but there is no consensus on the specific pressure settings or engineering solutions. Multiple competing views on how to approach the problem remain unresolved.
Limitations include the lack of detailed specifications for the panels, uncertainty about the cooling system's design, and the potential for varying conditions affecting pressure and flow rates.
SteelMaker
Gentlemen,
I work in the steel industry, specifically in the melt shop department which operates electric arc furnaces. My question is that those electric arc furnaces have water cooled panels around the furnace, and I am trying to install relief valves on the panels. the molten metal and slag in on the side of the panels can reach 3050 F on the molten metal side. the panel have circuits of water running through them to cool them while making steel. we are trying to learn at what pressure should we set the relief valves to? basically we worry when the panel starts leaking and the water start to convert to steam in the panels. I attached pictures of typical panel. please let me know what are your thoughts on calculations for flow, pressure drop, pressure setting for relief valves. a lot of time the circuits in the panels have one outlet and one inlet. Thanks for any help.
I think more info might be needed to get more responses. You acknowledge that the boiling point of water changes with pressure which is a good start. Where does the heat go after the water takes it away (giant radiator, cooling pond etc.)? What is it's pressure rating? What pump or type of pump is used? How many btu's need to be dissipated? Or can be dissipated? I assume these panels are plumbed "in parallel". What diameter the pipes are and rough length would be needed to estimate head loss and flow rate.
just some thoughts to get the topic flowing
Who specifies, makes or supplies the panels? They should be designed to work at a certain working pressure and a maximum safe over pressure. The Pressure Relief Valve (PRV) will need to be set somewhere between the two depending how accurate it is and the consequences if it opens unnecessarily.
You also need to check the capacity of the PRV not just the operating pressure. For example in an emergency can the water escape fast enough to lower the pressure or will the pressure keep rising even with the PRV open! This is especially true if the water can boil and turn to steam when the PRV opens. You also need to think about where any water or steam will be vented. High velocity steam jets are no joke.
Steam explosions are particularly dangerous. It's not like being splashed with 100C water. When steam condenses on skin it delivers a lot of energy due to the high latent heat of vaporisation that water has.
To me honest your post fills me with horror. If these panels aren't being designed and tested to meet a carefully thought out specification I strongly suggest you bring this to the attention of whoever is the safety officer for the plant.
This is highly dangerous to try to engineer on an Internet forum. Please consult the vendor or a registered professional engineer.
Thread locked.
