Shaft system for a bevel gear reducer
  • Topic: Engineering
  • Thread starter jojosg
16 replies · 1K views · last reply
jojosg
The following figure shows a shaft system used in bevel-gear reducer. Given condition: mean diameter of pitch circle dm=30mm, Ft=1300N, Fr=400N, Fa=250N, n=14300r/min, af=1.5. please evaluate the bearing lifespan, where the bearing 30305 is used. Please also give explain the meaning of bearing designation 30305. (For Bearing used C=43200N, e=0.37, if Fa/Fr < e, X = 1, Y = 0; if Fa/Fr > e, X=0.4, Y=1.6, Fi=Fr/(2Y))
Bearing designation definition: 30305
[tex]
\text{3: Tapered roller bearing; 03: dimension series; 05: bore } d=5\times5=25\ \mathrm{mm}
[/tex]
Equivalent dynamic load:
[tex]
P = a_f\left(XF_r + YF_a\right)
[/tex]
Induced thrust:
[tex]
F_i = \frac{F_r}{2Y}
[/tex]
Bearing life in hours:
[tex]
L_{10,\mathrm{h}}=\frac{10^6}{60,n}\left(\frac{C}{P}\right)^p
[/tex]
For roller bearings, [itex]p=10/3[/itex].
Free-body diagram of a shaft with bearings 1 and 2 on the left, a bevel gear on the right, and dimensions 100 and 50 along the shaft and 30 vertically. Forces shown are FA, FT and FR at the gear.
I need to evaluate bearing life and explain the meaning of bearing designation 30305. I am not confident with my axial force balance step.
First, calculate resultant radial loads on bearing 1 and bearing 2.Vertical plane moment balance:[tex]F_{r2,v} = \frac{(F_t+F_r)\cdot 150}{100} = \frac{(1300+400)\cdot 150}{100}=2550\ \mathrm{N}[/tex][tex]F_{r1,v} = 1300+400 - 2550 = 850\ \mathrm{N}[/tex]
Horizontal plane, axial force creates bending moment [itex]M=F_a\cdot d_m/2 = 250 \times 15 = 3750\ \mathrm{N\cdot mm}[/itex][tex]F_{r2,h}=\frac{F_r\cdot 150 + 3750}{100}=637.5\ \mathrm{N}[/tex][tex]F_{r1,h}=|400 - 637.5|=237.5\ \mathrm{N}[/tex]
Resultant radial loads:[tex]F_{r1}=\sqrt{F_{r1,v}^2+F_{r1,h}^2}=\sqrt{850^2+237.5^2}=882.5\ \mathrm{N}[/tex][tex]F_{r2}=\sqrt{F_{r2,v}^2+F_{r2,h}^2}=\sqrt{2550^2+637.5^2}=2628.4\ \mathrm{N}[/tex]
Induced thrusts, using [itex]Y=1.6[/itex]:[tex]F_{i1}=\frac{F_{r1}}{2Y}=\frac{882.5}{2\times1.6}=275.78\ \mathrm{N}[/tex][tex]F_{i2}=\frac{F_{r2}}{2Y}=\frac{2628.4}{2\times1.6}=821.38\ \mathrm{N}[/tex]
Axial balance check:[itex]F_{i2}+F_a = 821.38 + 250 = 1071.38 > F_{i1}[/itex]So:[tex]F_{a1}=F_{i2}+F_a=1071.38\ \mathrm{N},\quad F_{a2}=F_{i2}=821.38\ \mathrm{N}[/tex]
Check ratios against [itex]e=0.37[/itex]:[tex]\frac{F_{a1}}{F_{r1}}=\frac{1071.38}{882.5}=1.214>0.37 \implies X_1=0.4,;Y_1=1.6[/tex][tex]\frac{F_{a2}}{F_{r2}}=\frac{821.38}{2628.4}=0.312<0.37 \implies X_2=1,;Y_2=0[/tex]
Equivalent loads:[tex]P_1 = a_f\left(X_1F_{r1}+Y_1F_{a1}\right)=1.5\left(0.4\times 882.5 + 1.6\times 1071.38\right)=3045.4\ \mathrm{N}[/tex][tex]P_2 = a_f\left(X_2F_{r2}+Y_2F_{a2}\right)=1.5\left(1\times 2628.4 + 0\right)=3942.6\ \mathrm{N}[/tex]Since [itex]P_2>P_2[/itex], Bearing 2 governs life.
[tex]L_{10,\mathrm{h}}=\frac{10^6}{60\times 14300}\left(\frac{43200}{3942.6}\right)^{10/3}[/tex]
My uncertainty:I’m not fully confident in the horizontal plane moment calculation from the bevel gear axial force, and also unsure whether my axial thrust balance direction is correct for this opposed tapered roller pair. Could you verify?
You have some mistakes. Let's start with your free body diagrams of the axle loading in each plane, can you produce them?
1) There should be three (not two), and one should have a moment in addition to the reaction forces acting on it (the axle).
2)Why does ##F_A## have two orthogonal components in the top diagram ( it should be an axial load for that plane) and you've flipped the direction of the axial force from the accompanying problem diagram?
Let's just do one for now. Imagine you are looking the plane shown in the original diagram. Show the FBD of the axle for that plane including forces and moments.
Free-body diagram of a shaft supported by bearings 1 and 2, with reactions R1 and R2 spaced 100 apart, a gear loaded by axial force FA, tangential force FT and radial force FR, a 50 offset, a 30 height and a moment M = 7500 N·mm.
Like this?
jojosg said:
better( still not quite right); it is not an internal moment. The moment is an external moment ( that means it's an external load on the axle ). You don't flip the direction or handedness of known external loads when analyzing the beam. You seem to be confused on that point, perhaps thinking that you are looking at internal moments/forces?
Think about which way ##F_A## bends(rotates) the beam, and which your applied ( effective moment load from ##F_A##) external moment bends (rotates) the beam. Does the latter match the former?
Edit: I'm going to help you out here, if you don't understand why the diagram is this way please say something. This is the effective loading on the shaft in the ##xy## plane.
Free-body diagram of a horizontal shaft in the xy plane with arrows for two support reactions, an applied vertical load, an axial load and a moment at the right end.
Use ## \sum F_y = 0 ## and ##\sum M_p = 0## to determine the vertical reactions. We'll go from there.
Given data
[itex]d_m=30\ \text{mm},\ F_t=1300\ \text{N},\ F_r=400\ \text{N},\ F_a=250\ \text{N},\ n=14300\ \text{rpm},\ a_f=1.5,\ C=43200\ \text{N},\ e=0.37,\ X=0.4,\ Y=1.6\ (F_a/F_r>e),\ p=10/3[/itex]
1. Plane reactions
Tangential plane ([itex]F_t[/itex]):
[tex]\sum M_1 = 0 \Rightarrow R_{2t}(100) - 1300(150) = 0 \Rightarrow R_{2t} = 1950\ \text{N}[/tex]
[tex]\sum F_y = 0 \Rightarrow R_{1t} = -650\ \text{N}[/tex]
Radial plane ([itex]F_r + \text{offset moment from }F_a[/itex]):
[tex]M = F_a \cdot 30 = 7500\ \text{N·mm}[/tex]
[tex]\sum M_1 = 0 \Rightarrow R_{2r}(100) - 400(150) - 7500 = 0 \Rightarrow R_{2r}=675\ \text{N}[/tex]
[tex]\sum F_y = 0 \Rightarrow R_{1r} = -275\ \text{N}[/tex]
[tex]F_{r1} = \sqrt{R_{1t}^2 + R_{1r}^2} = 705.78\ \text{N}[/tex]
[tex]F_{r2} = \sqrt{R_{2t}^2 + R_{2r}^2} = 2063.52\ \text{N}[/tex]
2. Induced axial thrusts
[tex]F_i = \frac{F_r}{2Y}[/tex]
[tex]F_{i1}=220.56\ \text{N}[/tex]
[tex]F_{i2}=644.85\ \text{N}[/tex]
Opposed bearing arrangement, assumed external thrust carried by bearing 1:
[tex]F_{a1}=F_{i2}+F_a=894.85\ \text{N}[/tex]
[tex]F_{a2}=0[/tex]
3. Equivalent dynamic loads
Bearing 1: [itex]F_{a1}/F_{r1}=1.268>e[/itex]
[tex]P_1 = XF_{r1}+YF_{a1}=1714.07\ \text{N}[/tex]
Bearing 2: [itex]F_{a2}/F_{r2}=0<e[/itex]
[tex]P_2 = F_{r2}=2063.52\ \text{N}[/tex]
With application factor:
[tex]P_{d1}=a_f P_1=2571.11\ \text{N}[/tex]
[tex]P_{d2}=a_f P_2=3095.28\ \text{N}[/tex]
4. [itex]L_{10}[/itex] life (Shigley)
[tex]L_{10} = \left(\frac{C}{P_d}\right)^p 10^6\ \text{rev}[/tex]
[tex]L_{10h} = \frac{L_{10}}{60n}[/tex]
[tex]L_{10h,1}\approx 14160\ \text{h}[/tex]
[tex]\boxed{L_{10h,2}\approx 7629\ \text{h}}[/tex]
Bearing 2 governs the system life.
5. Bearing designation 30305
3 = tapered roller bearing; 03 = dimension series; 05 = bore code, bore = 25 mm.
My question:
Is my axial thrust balance correct? I assumed [itex]F_{a1}=F_{i2}+F_a[/itex] for the opposed mounting.
This is my understanding.
jojosg said:
Given data
Slow down.
1) You don't seem to understand the direction of the effective load from the axial force. !This is important! What is the direction of the moment from ##F_A##? You are getting the wrong reaction forces because of this misunderstanding. This kind of thing is fundamentally bad...the kind of misunderstanding that will haunt you. Talk to me about what your line of thought is here so we can fix the misconception.
2) Clarify this with your prof. The pitch Diameter is given as 30 mm in the problem statement. However, the drawing shows the pitch Radius as 30 mm. So which is correct?
erobz said:
Slow down.
My prior interpretation was that [itex]F_a[/itex] acts along the shaft centreline and only produces axial thrust on the bearings. From your comment, I now think [itex]\mathbf{F}_a[/itex] acts at the gear tooth on the pitch circle, offset from the shaft axis by pitch radius [itex]r_m[/itex]. This offset creates a bending moment [itex]M = \mathbf{F}_a r_m[/itex] within the FBD plane, which affects the bearing reaction forces.
I checked with my professor on the geometry conflict: we follow the written problem statement, so [itex]d_m=30\,\text{mm}[/itex], [itex]r_m=15\,\text{mm}[/itex]. The diagram marking of 30 mm as a radius is to be disregarded.
Is this the correct way to interpret the moment from [itex]\mathbf{F}_a[/itex]?
Yeah, ##F_A## does create a bending moment (as well as a pure axial load). That moment is included in your analysis for ##\sum M_1 = 0 ##, but you are saying it is clockwise. Why do you think it is a clockwise moment on the shaft?
I assumed clockwise as a starting guess for the moment, planning to rely on the sign from the equilibrium equation to show if the true direction was opposite. I had not worked out the geometric moment direction from [itex]F_A[/itex] yet.
You can't do that. It is a known load, it has a known direction. It is not an unknown.
For an example: what you are doing is like saying ##F_r## inexplicably acts "up" as opposed to the way it actually acts. The actual load ##F_r## (its magnitude and direction ) are fixed. If you flip it incorrectly thinking you can "assume" a direction for it, you aren't going to get the same results for R_1 and R_2. The same goes for a known moment load caused by known force load ##F_A##, it's not assumed, it's a given.
Radial plane ([itex]F_R[/itex] + counter-clockwise applied moment [itex]M[/itex])
[tex]\sum M_1 = 0 \Rightarrow 100 R_{2y} - 400(150) + 7500 = 0[/tex]
[tex]R_{2y} = 525\ \mathrm{N}[/tex]
[tex]\sum F_y = 0 \Rightarrow R_{1y} + 525 - 400 = 0 \Rightarrow R_{1y} = -125\ \mathrm{N}[/tex]
Tangential plane ([itex]F_T[/itex])
[tex]\sum M_1 = 0 \Rightarrow 100 R_{2t} - 1300(150) = 0[/tex]
[tex]R_{2t} = 1950\ \mathrm{N}[/tex]
[tex]\sum F_y = 0 \Rightarrow R_{1t} + 1950 - 1300 = 0 \Rightarrow R_{1t} = -650\ \mathrm{N}[/tex]
[tex]F_{r1} = \sqrt{R_{1t}^2 + R_{1y}^2} \approx 661.91\ \mathrm{N}[/tex]
[tex]F_{r2} = \sqrt{R_{2t}^2 + R_{2y}^2} \approx 2019.44\ \mathrm{N}[/tex]
ok, you flipped it. Do you truly get why it must be this way, or did you just infer it must be the wrong sign? I ask because it's most important that I'm getting through to you not that you get the correct numerical result.
I’m still trying to wrap my head around this. From the original diagram, [itex]F_A[/itex] points left and sits above the shaft centreline. This creates a counter‑clockwise moment. Is [itex]F_A[/itex] indeed the governing factor for this bending moment?
yeah, ##F_A## is given ( direction by diagram and magnitude by problem statement ). It points to the left and is above the centerline. This absolutely creates a counter-clockwise moment on the beam.
This is equivalent loading to this:
It is NOT equivalent loading to this:
to convince yourself of this. Ask "What does ##F_A## want to do to the beam?" Which way would it want to push it, and which way would it want to spin it? Then look at the "equivalent" loadings above, which one agrees with your assessment for the effects of the original loading?
Just to nail this point home. This ( ##F_A## and its point of application) is a known load. For instance If it was a building, would you assume the weight force was up ( opposite the gravitational field), and let the equilibrium equation decide what the reactions at the ground would be? You'll get an answer that way...
jojosg said:
... and also unsure whether my axial thrust balance direction is correct for this opposed tapered roller pair. Could you verify?
I am not sure whether it has been discussed above, but the diagram seems to indicate that only bearing 2 is able to resist the axial component Fa of the gear force.
Bearing 1 is unable to support axial forces other than any in the left-right direction, since it has been installed in a reversed position respect to bearing 2.
Also, if the shaft is rigid enough, and because this type of bearing (tapped rollers) should not be subjected to moments in any direction, any moment induced by perpendicular components of the gear force, should be considered as resultant purely radial forces acting on each bearing, with different magnitudes (more on bearing 2 than on bearing 1) and with opposite directions.
Please, see:
https://www.skf.com/us/products/rol...279e9234&sort=PIM001|Floating point|ASCENDING
https://cdn.skfmediahub.skf.com/api...edium/0901d196805fd45c_pdf_preview_medium.pdf
:cool:
