What Would Happen to a Shattered Earth-Like Planet?
  • Thread starter Thread starter DaveC426913
    Planet
The discussion centers on the hypothetical scenario of an Earth-like planet being shattered into large pieces through an artificial catastrophe, specifically using a toroidal explosion from antimatter. The largest fragments are theorized to be no more than a couple of hundred miles across due to gravitational collapse. Over a century, these pieces would spread into arcs around the sun, with the northern and southern hemispheres forming molten planets. The moon would also be ejected into its own trajectory, while smaller fragments would retain irregular shapes.
  • Understanding of planetary geology and structure
  • Familiarity with explosive physics, particularly antimatter reactions
  • Knowledge of gravitational forces and their effects on planetary bodies
  • Basic concepts of orbital mechanics and celestial dynamics
  • Research the effects of antimatter explosions on planetary structures
  • Explore gravitational collapse and its implications for large celestial bodies
  • Study the formation and evolution of asteroid belts and their origins
  • Investigate the dynamics of celestial bodies in solar orbits post-catastrophe
Writers, astrophysicists, and science fiction enthusiasts interested in planetary destruction scenarios and their aftermath in a fictional context.
DaveC426913
There's a short story rattling around in my head. The premise involves an Earth-like planet that has been shattered (not reduced to rubble, but cracked into large pieces).
It is an artificial catastrophe, to be sure, but exactly what form of weapon or other destructive force was used is open to imagination (you are welcome to posit causes that will lead to the effect I'm looking for, but it is not important).
What I'm interested in is what form the shards would take. (this would likely be dependent on the nature of the destructive force). I'm looking for the least destruction required to separate a planet into two or more pieces that do not immediately recombine.
What might I expect the planetary environs to be, say, a century or so after the rending asunder. Obviously, after rounding the sun a hundred times, some of it will be quite spread out into, not a full ring, but an arc.
My primary question is about how the largest pieces might fare. The Earth is mostly high-viscosity liquid, so the largest pieces couldn't be more than - what? - a hundred miles thick? If that's true, is it safe to assume that no single piece could possibly measure more than a couple of hundred miles across? Any broader and they would simply collapse in on themselves by their own gravity like an eggshell in a closed fist.
Input?
It's still speculated, the last I heard, that the asteroids are remnants of such an occurrence. Maybe you can start there and work around it a bit.
Well, all our asteroids are ancient and have been reduced by collisions and self-collapse to near spheroids. So not what I'm after.
DaveC426913 said:
two or more pieces
DaveC426913 said:
more than - what?
Take a sp. gr. of ~ 3 for crustal material (the rest ain't going to be too terribly interesting), a crushing strength of 5-10 kpsi (70 MPa?), Fgfrag ~ 3000d3Gmtest/r2 = 1.6 x 10-6N x r, where r = d/2 is a "mean" radius for the fragment --- solve for a mean diameter or radius that exceeds crush strength for whatever geographic relief is necessary for the story.
I think the best approach would be to allow an antimatter rope (or other suitable explosive) to descend onto the equator - so that a toroidal explosion squeezes the Earth into two pieces. If the detonation was little more than minimal and occurred during an equinox, there would be two large pieces in solar orbits that would keep them apart for years.
Aside from the north and south hemispheres that would each form a molten planet, there would be "splash" from the equatorial section that was most directly squeezed.
The moon would head off in its own direction.
Large pieces would collapse under their own weight into a sphere. Only small asteroid sized pieces could have weird shapes.
  • · Replies 17 ·
