Shell Side Fluid Velocity of Baffled HX & Re - Nobody knows last resort
Calculating the shell side fluid velocity for a baffled shell and tube heat exchanger (HX) is challenging, particularly when determining the Reynolds number for this flow. Key variables include mass flow rate, number of tubes, tube bundle length, number of baffles, and the inside diameter of the shell, along with fluid properties like specific heat, density, and viscosity. Users note that while calculating the tube side velocity is straightforward, the shell side presents more complexity. A recommended resource for further guidance is a specific book that addresses these calculations. Overall, assistance is sought to clarify the equations and methods applicable to this scenario.
PHYS&MECHE
Shell Side Fluid Velocity of Baffled HX & Re -- Nobody knows last resort
Problem:
I need to know how to calculate the shell side fluid velocity for a Shell&Tube HX with *Baffles*. Also, the reynolds number for this flow
Known:
ms -Mass flow on shell side
Nt -Number of tubes
Lt -Length of tube bundle
Nb - Number of Baffles
Dis -Inside Diameter of Shell
Vs -Volumetric flow rate
--Also I know all fluid properties for shell side fluid i.e. Cp, rho, viscosity...
Comments: I have completed this for the tube side it was very simple but the shell side is difficult and can not find any equations to apply.
Design Engineer needing help!
I will have to order the book I can't seem to figure it out. Thank you.
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
