Shell & Tube Falling Film Evaporator Nickel Tubes Collapsed
The discussion centers on the collapse of nickel tubes in a triple effect caustic evaporator during offline maintenance. The incident occurred after the evaporation was drained and the tubes were exposed to atmospheric conditions, leading to potential vacuum collapse due to temperature gradients and lack of vacuum relief. The mechanical department is tasked with replacing the damaged tubes, which were found severely collapsed after a delay in crane arrival and subsequent maintenance activities. The primary cause identified is the abnormal expansion of nickel tubes due to washing with water at a lower temperature compared to the tube skin temperature.
  • Understanding of triple effect evaporator systems
  • Knowledge of nickel tube construction and properties
  • Familiarity with vacuum collapse phenomena
  • Experience with maintenance procedures in industrial settings
  • Research vacuum collapse mechanisms in evaporator systems
  • Study the effects of temperature gradients on metal expansion
  • Learn about maintenance best practices for nickel tubes in caustic environments
  • Investigate the design and implementation of vacuum relief valves in evaporators
Process engineers, maintenance personnel, and industrial equipment designers involved in the operation and upkeep of evaporator systems, particularly those using nickel tubing in caustic applications.
sorter
An unfortunate incident happened at our triple effect caustic evaporator (32w.t% to 51w.t%). The third effect (highlighted red) where major steam (~12-13bar depending on flowrate) assisted evaporation take place, here for some reason Ni tubes get severely collapsed, while the plant was offline
Construction ..generally for falling film internals
P&ID (illustrated)
www.mediafire.com/view/6dumme618wr63o6/Evp2_P-1442_P_I_Diagram_process.jpg
Damage done
http://www.mediafire.com/view/38zlrmb8hm360hk/P_20151210_152624.jpg
http://www.mediafire.com/view/2r1izd5r3doylts/P_20151210_152653.jpg
http://www.mediafire.com/view/xxwqft25j17f5b1/P_20151210_152754.jpg
http://www.mediafire.com/view/93hlv4byr6x6t6h/P_20151210_152826.jpg
So it went like this
@day1 ..we drained the evaporation while cooling it slowly (~2hrs) to ~60celsius for mechanical maintenance of effect_3. During this time level transmitter was dismantled & taken out from span of effect_3 (a dp transmitter) this therefore produced two potholes in our Ni made span which was now open to atmosphere ..& so were Ni tubes (see internal construction fig.)
@day2,3 ..crane to bring down this mammoth (6.3m length ~6000mm Ni 81 tubes) effect_3 didn't arrive, it was idly sitting there ..ambient temperature here in winter did approach ~3celsius. Do recall span of effect_3 is open to atmosphere so vacuum (via condensation) isn't possible
@day4 ..crane arrived ..supports unbolted & effect_3 was on the floor but the mild steel shell appeared to be ~80celsius indicating minor steam passing into shell (diaphragm steam valve is passing). We (process engineers) didn't notice the tubes though. Had this being done we would have known whether the tubes are inwards bulged merely by viewing across them
@day5 ..in mechanical workshop our jaws dropped when we were asked to view Ni tubes of effect_3.
HERE STARTS OUR DISCUSSION
Mechanical department was to replace any leak Ni tubes so they have to wash every tube because it was laced with NaOH 50w.t% ..Is it possible that because of temperature gradient of washing water & skin temperature of Ni tubes (recall ~80celsius) Ni abnormally expanded & while its two extreme ends are welded indirectly to MS shell it may have twisted & collapsed. What other reasons you think of?
While I really can't follow your explanation or procedures, it sure looks like vacuum collapse of the tubing. Happens when steam cools in a vessel or system without a vacuum relief valve. I've seen it in tanks and thin tubes like these.
16K
