SHM: Which is amplitude and which is displacement?
The discussion centers on calculating the acceleration and velocity of a piston in simple harmonic motion, given a stroke of 150mm and an engine speed of 3500rpm. Participants clarify that the amplitude is defined as half the stroke, equating to 75mm, while the displacement is the full stroke of 150mm. The correct calculations yield a maximum velocity of 55m/s and a maximum acceleration of 20762 m/s², confirming that the stroke represents the amplitude in this context.
  • Understanding of simple harmonic motion equations
  • Knowledge of angular velocity calculations
  • Familiarity with the concepts of amplitude and displacement
  • Ability to perform unit conversions (e.g., mm to meters)
  • Study the derivation of simple harmonic motion equations
  • Learn about angular velocity and its applications in mechanical systems
  • Explore the relationship between amplitude and displacement in oscillatory motion
  • Investigate the effects of engine speed on piston dynamics
Students studying physics, mechanical engineers, and anyone involved in automotive engineering or dynamics of oscillatory systems.
richyr33
Calculate acceleration and velocity of a piston. Stroke is 150mm and engine speed 3500rpm
Using simple harmonic motion equations
a = -ω^2*s
v = ω*√A^2 - s^2
ω = 2*∏*f
v = velocity, a = acceleration, f = frequency
ω=angular velocity, s=displacement, A = Amplitude
worked out frequency by 3500/60=58.3Hz
angular velocity = 366.31 radians/sec
Problem i have is I'm not sure what value i use for amplitude and what value i use for displacement. I believe that amplitude would be half the stroke thus being 75mm and displacement being the stroke of 150mm. However inserting these values into the equation to calculate velocity gives a negative figure which then cannot be square rooted. Any help would be appreciated. Thanks
what equations are you using specifically?
Acos(kr-wt)=x? = Acos(wt)=x where r=0 for the wave front.
w= 3500x60 rad/s
when it says stroke does it mean from the max to min or to the middle?
v = -wAsin(wt)
a= -w2cos(wt)did you write out the full question because it doesn't seem complete imo
That is the question in full. It just says the stroke of the engine is 150mm. The only pieces of information I am missing are A=Amplitude and s = displacement. Only thing that is confusing me is the difference between the two. Is amplitude the distance from bottom of stroke to top or is that the displacement?
displacement is the distance traveled from the center as every book I've ever seen states it.
I think in this case the displacement and amplitude are the same value as the question asks for maximum velocity which would be when displacement is at a maximum, which would be distance from the centre like you say, which is 150mm/2.
I came up with an answer of 27.47m/s for velocity and 10063.73m/s/s for acceleration.
Thanks for your help, appreciated.
Amplitude is the maximum value of the displacement. I would say that in your example the stroke (150mm) is the amplitude
3500rpm means the frequency is 58.3Hz which means that ω = 2πf = 366...just as you found.
I would take 150mm (0.155m) to be the Amplitude which means that
max acceleration = ω^2*A = ω^2*0.155 = 20762 m/s^2
Max velocity = ωA = 366*0.15 = 55m/s
Hope this helps
I think you have to take 'stroke' to mean amplitude, it makes sense to refer all distances from the equilibrium position.
I am certain this is the convention.
Yes this is exactly what's confusing me and I have two differing explanations in my notes which adds to it! I have worked it out for the stroke being the amplitude as well and i have the same answers as you have worked out and I have also done it as above where i have taken the amplitude to be the stroke halved.
wouldn't the equilibrium point be half way up the cylinder thus making the stroke twice the amplitude?
RichYr33
What you say is a very good point and could be correct... I don't know!
Do you know the answer?
Either way you know how to do the calculation which is the important thing
  • · Replies 27 ·
  • · Replies 17 ·
  • · Replies 18 ·
