Shortest distance between two lines (vector algebra)
11 replies · 18K views · last reply
FelixISF
line l1 : x=2 y= -1 + p z= 2p
line l2 : x=-1 + t y=1-3t z=1-2t
Find the shortest (exact) distance between l1 and l2.
That's what I am looking for!
Thanks!
You have to show your attempt at a solution before we can help you.
Thanks
Matt
I don't see your point. I have tried to solve the problem but didn't manage to do so, cause I can't find the right formulas.
All I am asking for is the information on what formulas might be helpful.
Do you expect me to write some attempt here, even if the wrong equations were used? what's the point?
Yes, you are expected to post your work. If it is wrong then we can help to steer you onto the right path. So yes, write your attempt and indicate where you think you went wrong and then we can help.
That is my point.
Thanks
Matt
I tried to use the following equation:
d = sqrt((x1-x2)^2+(y1-y2)^2+(z1-z2)^2), but it doesn't give me the right answer.
whats wrong then ?
The distance formula is,
d = sqrt((x2-x1)^2+(y2-y1)^2+(z2-z1)^2)
Well, the first thing you should do is substitute in you values for the quantity (x2-x1), square that quantity, and then simplify it if you can. Do the same for the other two quantities. Add them together and then take their square root.
Thanks
Matt
Thanks!
I will give you a few hints. The first is that you don't want to use distance formulas. From your two lines you can get direction vectors D1 and D2, right? And the cross product N = D1 X D2 would be normal to both lines. From your lines you can also get points P1 and P2 on line1 and line2 and use them to get a vector V across from one line to the other. Can you see that the distance between the lines would be the absolute value of the component of V on N? Try that.
there's no difference between these 2..
Can you please explain this a little more? I see that N=D1(cross)D2 is normal to both vectors, hence normal to the plane of the two vectors D1 and D2. Also the vector V we formed from one line to another has to be in the plane of the vectors D1 and D2. Therefore N is normal also to V; now how can V have any component on another vectos normal to it; the component of V on N is zero. Am I right?
Thanks
TJ
The solution doesn't count as a relevant equation.
FelixISF said:
Thanks!
Shhh! It's rude to point out that a post is completely useless. Oh wait...
**Shortest distance between 2 lines drawn in 3D**
R1(t) = (x1(t), y1(t), z1(t)) // t is the independent variable for line 1
R2(s) = (x2(s), y2(s), z2(s)) // s is the independent variable for line 2
D = R1(t) - R2(s) // distance between anywhere on the 2 different lines
We first need to find, for a given point on line 1 (ie at position t), where the shortest distance from this point across to line 2 occurs.
So we start by finding the square of the length of the vector D (ie its dot product (denoted by D.D); this just gives us a nice positive equation to work with). We then find where the derivative of this dot product with respect to s is equal to 0, while also making sure that we are dealing with a minima and not a maxima. From this, we will find the function s(t) (see below):
∂[D.D]/∂s = 0 [1] // derivative of the dot product
∂^2[D.D]/∂s^2 > 0 // ie the double derivative must be positive to ensure that it's a minima
*Note: as there were 2 independent variable in equation D, we needed to use the partial derivative.
Now solve equation [1] to find s(t) // s as a function of t.
What equation s(t) tells us, is that for a given point t (on line 1), the shortest distance to line 2 can be found at point s (on line 2).
So, now all we need to do is find which value of t (on line 1) will give us the overall shortest distance (ie when comparing all the shortest distances already found for the different values of t).
First we re-write equation D using function s(t) (which was found from equation [1] above:
D = R1(t) - R2(s(t)) [2] // now equation D is entirely written with respect to the single independent variable t
And similarly (as we did before):
d[D.D]/dt = 0 [3] // derivative of the dot product (calculated using equation [2])
d^2[D.D]/dt^2 > 0 // ie the double derivative must be positive to ensure that it's a minima
Solving equation [3] to find t, we now have a value (point t on line 1), where the overall shortest line occurs.
Substituting this value of t into equation [2] and finding the length of this vector (ie the square root of its dot product), one should arrive at the value for "the shortest distance between 2 lines drawn in 3D".
I think this approach should also work for n-dimensions (which we would clearly need).
