Shoudn't the fraction -2/-1 be less than one?
The discussion centers on the confusion surrounding the fraction -2/-1 and its value. While it seems intuitive that a smaller numerator than denominator should yield a result less than one, this only applies when both numbers are positive. Dividing two negative numbers results in a positive value, specifically 2 in this case, which is greater than one. The key takeaway is that the rules governing fractions differ between positive and negative numbers, and the ratio concept is crucial to understanding this. The thread concludes that the initial question has been adequately addressed.
kay
Because technically, the numerator is smaller than the denominator as −2<−1
I know it's an extremely stupid question.
I mean I know that I can just multiply −1 to the numerator and the denominator and I'll get 2/1 which is greater than one.
But what exactly is happening here?
A number that is supposed to be less than one is coming out to be greater than one;double, to be precise.
Likes fireflies
Mathematics news on Phys.org
Starting with
-2<-1
if you divide both sides by the negative number -1, you're supposed to reverse the inequality sign. So
-2&lt;-1
\frac{-2}{-1}&gt;\frac{-1}{-1}=1
Also, the numerator being smaller than the denominator isn't the rule for numbers to turn out smaller than 1. The numerator is TWICE the size of the denominator, hence the result should be 2. Fractions are about ratios, not comparisons.
Likes fireflies
You appear to be using a rule that "a fraction is less than one if the numerator is less than the denominator". That is only true if the denominator is positive.
If n< d then n/d< 1 requires that d be positive.
Likes fireflies
I think you're seeing the negative side of real numbers just as you do the positive sides. What you described goes for the positive side, but conversely for the negative side. The neagative is opposite of the positive. So if small-number-numerator-over-big-number-denominator is a proper fraction on the positive side, then it's an improper fraction on the negative, that is with the same small-number-numerator-over-big-number-denominator arrangement.
N
No, when numerator is smaller than denominator then the fraction is always less than 1. Here, numerator 2>denominator1 so, 2/1 is greater than 1
And -2<-1
Yeah, I mistook. The converse relation for negative sides
No. Do the division, keeping in mind that when both the numerator and denominator are the same sign, the value of the fraction is positive.
$$\frac{-2}{-1} = 2 > 1$$
If you are using a "rule" that ignores the above property of division, that rule is bogus.
The question has been asked and answered, so closing this thread.
Likes berkeman
17K
  • · Replies 21 ·
