Show that a series is divergent
4 replies · 2K views
vbrasic
Show that $$\frac{(-1)^nn!}{z^n}$$ is divergent.
We can use the ratio test, which states that if, $$\lim_{n\to\infty}\bigg|\frac{a_{n+1}}{a_n}\bigg|>1$$ a series is divergent.
Applying the ratio test, we find that $$\bigg|\frac{a_{n+1}}{a_n}\bigg|=\frac{n+1}{z}.$$ I'm having trouble showing why the limit of this must be greater than one.
Hi vbrasic:
I suggest you think about the numerator and he denominator separately with respect to which gets larger than the other as n changes.
Regards,
Buzz
Your ration ##|a_{n+1}/a_n|## is wrong: you need ##|z|## in the denominator (and that is crucial, not just a minor quibble).
Added in the missing absoute value. I think the reason it must be greater than one in the limit is because for any complex number, we may write it as ##re^{i\phi},## with magnitude ##r##. Given then that ##r## is finite, we have that the limit tends to ##\infty## because of the ##n## in the numerator. Does that sound okay?
Yes, it's OK. But is would be easier to just say that for any given ##z##, the quantity ##|z|## is some positive finite number, and eventually all the ##n+1## well exceed it.
