Show that a series is divergent
The problem involves demonstrating the divergence of the series $$\frac{(-1)^nn!}{z^n}$$ using the ratio test. The context is within the study of series convergence and divergence, particularly in relation to complex numbers.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of the ratio test and the limit of the ratio $$\bigg|\frac{a_{n+1}}{a_n}\bigg|$$. There is a focus on understanding why this limit must exceed one for divergence, with suggestions to analyze the growth of the numerator versus the denominator.
The discussion is ongoing, with participants providing guidance on how to approach the limit and questioning the assumptions made about the terms involved. There is acknowledgment of a correction regarding the absolute value in the denominator, and some participants are exploring the implications of the magnitude of complex numbers.
There is a mention of the importance of the absolute value in the denominator and the implications of the growth of factorial terms in the numerator. The discussion reflects on the behavior of the series as \( n \) approaches infinity, with varying interpretations of the limit's behavior.
vbrasic
Show that $$\frac{(-1)^nn!}{z^n}$$ is divergent.
We can use the ratio test, which states that if, $$\lim_{n\to\infty}\bigg|\frac{a_{n+1}}{a_n}\bigg|>1$$ a series is divergent.
Applying the ratio test, we find that $$\bigg|\frac{a_{n+1}}{a_n}\bigg|=\frac{n+1}{z}.$$ I'm having trouble showing why the limit of this must be greater than one.
Hi vbrasic:
I suggest you think about the numerator and he denominator separately with respect to which gets larger than the other as n changes.
Regards,
Buzz
Your ration ##|a_{n+1}/a_n|## is wrong: you need ##|z|## in the denominator (and that is crucial, not just a minor quibble).
Added in the missing absoute value. I think the reason it must be greater than one in the limit is because for any complex number, we may write it as ##re^{i\phi},## with magnitude ##r##. Given then that ##r## is finite, we have that the limit tends to ##\infty## because of the ##n## in the numerator. Does that sound okay?
Yes, it's OK. But is would be easier to just say that for any given ##z##, the quantity ##|z|## is some positive finite number, and eventually all the ##n+1## well exceed it.
