Show that Momentum is conserved in a reference frame
- Thread starter Tonia
- Start date
46 replies · 7K views
Tonia
- 96
- 0
Does checking it have something to do with this: v` = Mv/M + m ??
Staff Emeritus
Homework Helper
- 11,986
- 1,584
Don't over-complicate this. Don't waste all of those momenta you have just calculated.Tonia said:Does checking it have something to do with this: v` = Mv/M + m ??
Again to be clear, do this in the moving reference frame.
Add up the momentum prior to the collision.
How does that compare to the momentum after the collision?
Tonia
- 96
- 0
Momentum before collision(with respect to the reference frame):
2000kg times 10m/s = 20,000
1500kg times -10m/s = -15,000
both are the same as the momentum after the collision, so momentum is conserved?
Tonia
- 96
- 0
Oops I forgot that I already calculated that, now I'm confused.
Tonia
- 96
- 0
Does it hqave something to do with multiplying by the 1.43?
Tonia
- 96
- 0
2000kg times 20 m/s = 40,000
1500kg times 0m/s = 0
I think I'm doing this wrong.
Staff Emeritus
Homework Helper
- 11,986
- 1,584
11.4285714
Total momentum = (momentum of 2000 kg car) + (momentum of 1500 kg car)
After collision:
Total momentum = momentum of the two cars together.
Before the collision:Tonia said:2000kg times 20 m/s = 40,000
After collision:
Tonia
- 96
- 0
total momentum of car before collision = (mom. of 2,000 kg car) 40,000 + (mom. of 1500kg car) 0
total momentum after collision = 40,000 + 0 = 40,000
Tonia
- 96
- 0
Or is it 20,000 + (-15,000) = 5,000?? before collision
Tonia
- 96
- 0
The momentum after collision would be the 5,005 that I got from multiplying the 1.43 m/s times the (M+m)??
Staff Emeritus
Homework Helper
- 11,986
- 1,584
Yes.Tonia said:Or is it 20,000 + (-15,000) = 5,000?? before collision
Right.Tonia said:The momentum after collision would be the 5,005 that I got from multiplying the 1.43 m/s times the (M+m)??
Considering significant digits. those answers are the same.
However, if you use the value of 1.4285714 m/s (from 11.4285714 before rounding), you get very very close to the same thing.
Tonia
- 96
- 0
thank you for your help!
Tonia
- 96
- 0
One more question: How would you get the same answer using the 1.4285714 number?
Tonia
- 96
- 0
oh that's right, I forgot. 1.43 m/s times (M+m) = 1.43 m/s times 3500kg = 5, 005. Nevermind. Thanks!
Why Is Angular Momentum Not Conserved When a Cylinder Moves on a Stopping Board?
- Mark128
- · Replies 3 ·
- Introductory Physics Homework Help
- Replies
- 3
Momentum in different referance frames
- Murilo T
- · Replies 6 ·
- Replies
- 6
Kinetic energy in center of mass reference frame
- zenterix
- · Replies 3 ·
- Replies
- 3
Angular momentum of a system relative to a moving reference frame.
- Davidllerenav
- · Replies 1 ·
- Replies
- 1
Convert to Center of Mass Reference Frame
- rdemyan
- · Replies 9 ·
- Replies
- 9
Position of particle in inertial reference frame
- jasonchiang97
- · Replies 3 ·
- Replies
- 3
Momentum and Inertial Reference Frame
- jjkim623
- · Replies 1 ·
- Replies
- 1
Ball colliding with wedge: can momentum be conserved in partially elastic collision?
- Kishlay
- · Replies 30 ·
- Replies
- 30
Zero momentum reference frame and an inelastic collision
- Cutetys
- · Replies 4 ·
- Replies
- 4
Calculate velocities in COM reference frame for 2D collision
- rdemyan
- · Replies 27 ·
- Replies
- 27
