Show that the force applied by each rope
To solve the problem of two ropes supporting a 400N load at a 40-degree angle, the upward force exerted by both ropes must equal 400N. Each rope contributes to this force, and by using the sine function, the upward force from each rope can be calculated as T * sin(40). The equations derived show that the tension in each rope is approximately 312.5N, which rounds to about 300N as indicated in the problem. Thus, the forces applied by each rope effectively support the load while maintaining equilibrium.
Gughanath
please help!
i don't know how to solve da problem please help:
Two ropes are used to carry a load of weight 400N. The ropes are 40 degrees to the horizontal. Show that the force applied by each rope is to the container is abou 300N.
in order to hold up an object weighing 400 Newtons, you must apply a force of 400 Newtons upward to counter act the force of weight.
if you have two ropes, at 40 degree angles, holding it up, then you know that the combined upward force those ropes are exerting on the object must be 400 Newtons.
also, if you kow the "resultant" force in each rope, the force along the hypotenuse of the imaginary triangle, and the angle of each, then you can calculate what the ropes' upward forces are,
Fy = F * sin(angle), where Fy is the upward force, F is the total resultant force.
so it is 300 * sin(40) = 193 Newtons upward, and there are 2 ropes exerting the same force, so the total upward force is 386 Newtons. this isn't quite the 400 Newtons that we were looking for, but is close enough I think sonsidering they only used 1 sig. fig in the question, then 1 sig fig in the answer would be 400 Newtons.
By symmetry of the problem (I'm assuming it is because you didn't say it wasn't), the tension in each rope provides 200N of force in the upward direction. This upward force can also be written in terms of the tension T in the rope:
\mbox{upward force} = T \sin 40^{\circ} = 200N
Now you can solve for T, which is what you are looking for.
Here's my guess:
<br /> -T_1\cos(40)+T_2\cos(40)=0<br /> <br /> T_1\sin(40)+T_2\sin(40)-400N=0<br />
Those two are equations above are for your x- and y-coordinates. The force must equal zero.
The first equation simplifies into:
<br /> T_1=T_2\cos(40)/\cos(40)<br />
*T just stands for tension of cables 1 and 2
Now plug in T_1 into the second equation.
<br /> T_2\cos(40)\sin(40)/cos(40) + T_2\sin(40)=400 N<br /> <br /> = T_2\left(\cos(40)sin(40)/cos(40)\right)+sin(40)=400 N<br /> <br /> = T_2\left(1.28\right)=400 N<br /> <br /> = T_2=312.5 N<br />
Now you know tension of one cable, then just plug it in your original equation:
<br /> T_1=T_2\cos(40)/cos(40)<br /> <br /> = T_1=312.5 N<br />
They equal about 300 N, like the problem says.
*I'm new with the latex equation stuff, so I'm sorry if these equations have mistakes.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 25 ·
  • · Replies 19 ·
