Show that the Hamiltonian operator is Hermitian
The discussion centers on proving that the Hamiltonian operator, represented as $$\hat H = -\frac{\hbar}{2m} \frac{d^2}{dx^2} + V(x)$$, is Hermitian. The participants derive the inner product $$$$ and demonstrate that certain boundary terms vanish under the assumption that the wavefunctions $$f$$ and $$g$$ belong to the Hilbert space $$L_2(\mathbb{R})$$. They emphasize that while square integrable functions may not always satisfy the necessary conditions, physical wavefunctions do, thus reinforcing the need for operators to be "essentially self-adjoint" to ensure proper physical interpretation.
  • Understanding of quantum mechanics and the role of the Hamiltonian operator.
  • Familiarity with Hilbert spaces, specifically $$L_2(\mathbb{R})$$.
  • Knowledge of integration by parts and its implications in functional analysis.
  • Basic concepts of differential operators and their properties in quantum mechanics.
  • Study the properties of Hermitian operators in quantum mechanics.
  • Learn about the concept of "essentially self-adjoint" operators.
  • Explore the implications of boundary conditions on wavefunctions in quantum mechanics.
  • Review the mathematical foundations of Hilbert spaces and their applications in quantum theory.
Students and professionals in quantum mechanics, physicists focusing on operator theory, and anyone interested in the mathematical foundations of quantum observables.
JD_PM
Show that the Hamiltonian operator $$\hat H = -\frac{\hbar}{2m} \frac{d^2}{dx^2} + V(x)$$ is hermitian
##<f|\hat H g> = <\hat H f|g>##
$$<f|\hat H g> = \int_{-\infty}^{\infty} f^*\Big(-\frac{\hbar}{2m} \frac{d^2}{dx^2} + V(x) \Big) g dx$$
Integrating (twice) by parts and assuming the potential term is real (AKA ##V(x) = V^*(x)##) we get
$$<f|\hat H g> = -\frac{\hbar}{2m} \Big( f^* \frac{dg}{dx}|_{-\infty}^{\infty} - \frac{df^*}{dx}|_{-\infty}^{\infty} g + \int_{-\infty}^{\infty} \frac{d^2 f}{dx^2}g dx \Big) + \int_{-\infty}^{\infty} V^*(x) f^* g dx $$
In order to get the desired I had to assume that
$$f^* \frac{dg}{dx}|_{-\infty}^{\infty} = 0$$
$$\frac{df^*}{dx}|_{-\infty}^{\infty} g = 0$$
Then we get
$$<f|\hat H g> = -\frac{\hbar}{2m} \int_{-\infty}^{\infty} \frac{d^2 f}{dx^2}g dx + \int_{-\infty}^{\infty} V^*(x) f^* g dx = <\hat H f|g>$$
Checking the solution, they say that these terms indeed vanish 'because both f and g live on Hilbert space'.
But what property of Hilbert space makes this true?
Thanks.
I would better say that, if ##f## and ##g## are valid wavefunctions, then both belong to the complex space ##L_2(\mathbb{R})##, which is a Hilbert space if we consider the scalar product defined as
\langle f | g \rangle = \int_{-\infty}^{\infty} f^*(x)g(x)\ dx\ .
By definition, the complex space ##L_2(\mathbb{R})## is the set of all functions ##f## such that
\int_{-\infty}^{\infty} |f(x)|^2\ dx < +\infty\ ,
and this can only be true if ##f## vanishes at ##+\infty## and ##-\infty##. This is why you get that those terms are null when they are evaluated at infinity.
$$\frac{df^*}{dx}|_{-\infty}^{\infty} g = 0$$But what property of Hilbert space makes this true?
Thanks.
In general, those terms do not necessarily vanish for square integrable functions. You need a stronger condition here. The argument is that any physical wave-functions will obey these conditions and functions that do not are "pathological" and unphysical.
To quote Griffiths: any decent maths student can furnish you with a counterexample.
PS more fundamentally, the differential operator is not closed acting on ##L_2(\mathbb R)##. A counterexample is:
$$f(x) = \frac 1 x \sin(x^3)$$
Which is square integrable on ##[1, \infty)##, but its derivative is not.
Griffiths indeed states that 'there exist pathological functions that are square-integrable but do not go to zero at infinity'.
He suggests that if we are worried about that issue we simply 'restrict the domain of our operators to exclude them'. What does he mean, that we should not integrate over the whole infinity line?
He also states that such problematic functions do not arise in Physics; but why?
They must all go to zero at infinity. That's true for all square integrable functions. (Although you can mess around with having a sequence of discontinuities.)
What these functions have in common generally is unboundedness of derivatives, especially as the x-coordinate tends to infinity. Remember that in many ways real things are finite and considering a function defined on ##(-\infty, \infty)## is something of an approximation. It can't really go on for ever physically. What you can't have physically is a function that behaves more and more extremely as you go further away from the centre of the action. That's what makes them unphysical. This is true for the example I gave.
The restriction is on the set of functions you consider. One simple idea is that they must go to zero faster than any power of ##x##. I.e. eventually they must go to zero exponentially. Otherwise, your physical system is not contained.
I'd not consult Griffiths's QM textbook on such subtle issues. He is pretty sloppy in the foundations and mathematics. For a nice didactical introduction into these problems, which you can summarize to the conclusion that an operator that should represent an observable should not only be "Hermitian" but must even be "essentially self-adjoint", see
https://arxiv.org/abs/quant-ph/9907069
https://arxiv.org/abs/quant-ph/0103153
Thank you all, I now have a better understanding :)
Thank you for sharing these links vanhees71 :)
I am actually reviewing Griffiths' chapter 3 (formalism in QM), which contains:
3.1 Introduction to Hilbert space.
3.2 Observables.
3.3 Eigenfunctions of a Hermitian operator.
3.4 Generalized statistical interpretation.
3.5 Heisenberg's uncertainty principle.
3.6 Dirac notation.
I will complement both PDFs with Griffiths.
