Show that the Poisson Mass Function has the same value for λ and λ-1
The discussion centers on proving that the Poisson Mass Function, defined as p(x) = [e^(-λ) * λ^(x)]/(x!), has the same value at λ and λ-1. Participants suggest substituting λ-1 into the equation and equating p(x) with p(x-1) to demonstrate that p(x|λ) = p(x|λ-1). The key insight is that for a fixed λ, there exist two consecutive integers x and x-1 where the probabilities are equal, indicating the peak of the distribution. This proof involves algebraic manipulation and understanding of the properties of the Poisson distribution.
  • Understanding of the Poisson Mass Function and its formula.
  • Basic algebra for manipulating equations and solving for variables.
  • Familiarity with the concept of probability distributions.
  • Knowledge of integer properties and their implications in probability functions.
  • Study the derivation and properties of the Poisson distribution.
  • Learn about the relationship between λ and the shape of the Poisson distribution.
  • Explore the concept of peaks in probability distributions and how to find them.
  • Investigate the implications of integer values in probability functions.
Students studying probability theory, mathematicians interested in statistical distributions, and educators teaching the Poisson distribution in statistics courses.
Dakarai
Show that, quite generally, the Poisson Mass Function has the same value at λ (i.e. the average) and at (λ-1).
The Poisson Mass Function is
I started out by plugging in λ-1 into the equation to get p(x)= [e^(-λ-1) * (λ-1)^(x)]/(x!) but now I've gotten stuck. I'm not sure how to progress and prove this other than plug in different x and λ values. I've seen the graphs and such that indicate that λ and λ-1 share the same value, but I just can't figure out how to mathematically prove it.
If I'm not mistaken, ## \lambda ## does not change in what you are trying to show. One thing you can do is let ## p(x-1)=p(x) ## and solve for ## x ##.
Thank you for the advice. I'm very confused as to how this would actually show that p(x|λ) = p(x|λ-1).
This one is quite simple I think. ## e ^ {-\lambda} * \lambda^ {(x-1)}/(x-1)!=e ^ {-\lambda} * \lambda^x/x! ## . A little algebra and you have the answer. (Note x is an integer here).
Oh, I see where I'm confused. I'm not looking to solve for x-1, but rather λ-1. x remains x for this equation.
I reread this, and so I've attached the homework question (and the mentioned graph) to better help describe what I'm getting at. I'm very lost how to prove this.http://imgur.com/NyuuHmT
## \lambda ## is a parameter that is pre-selected that gives the shape of the curve. For a given ## \lambda ## there will be two consecutive integers, x-1 and x that have the same value for ## p ## i.e. ## p(x-1)=p(x) ##. That equation, in post #4 is easy to solve. ## x!/(x-1)!=x ##. I could show you the rest, but the Forum rules want the OP to do some of the work. When you get this answer for ## x ## it tells you where this "peak" occurs, i.e. for a given pre-selected ## \lambda ##, where the ## p ## function levels off with two equal values before it drops back down. If ## p(x) ## were a continuous function, you would set ## dp(x)/dx=0 ## to find this peak. Instead, ## x ## has only integer values, so you set ## p ## equal for two consecutive integers.
No: look at the diagram you supplied. The parameter ##\lambda## is fixed, and you are being asked to show that ##p(x|\lambda) = p(x-1|\lambda)## when ##x = \lambda##. That's all.
Likes Charles Link
