Show that there are vectors to get a basis
  • Context: MHB
  • Thread starter Thread starter mathmari
    Basis Vectors
The discussion revolves around the problem of demonstrating that a set of vectors can be extended to form a basis for a subspace of a vector space. Participants explore the conditions under which additional vectors can be added to an existing linearly independent set to achieve a basis for the subspace, utilizing induction as a method of proof.
  • Exploratory, Mathematical reasoning, Debate/contested
  • Some participants suggest using induction on the difference between the dimension of the subspace and the number of linearly independent vectors already present.
  • It is proposed that if the number of independent vectors equals the dimension of the subspace, the problem is resolved.
  • Participants discuss the necessity of finding a vector in the subspace that is not in the linear span of the existing independent set.
  • There is a suggestion that the inductive step involves extending the independent set by adding one vector at a time.
  • Some participants express uncertainty about whether the induction method being used is strong induction or not.
  • A detailed proof structure is proposed, outlining the base case, inductive hypothesis, and inductive step, but there is debate about the specifics of extending the independent set.
Participants generally agree on the need to extend the independent set to achieve a basis, but there is disagreement on the specifics of the induction method and the steps involved in the proof. The discussion remains unresolved regarding the classification of the induction used.
Limitations include the dependence on the definitions of linear independence and the dimensions of the subspace, as well as the assumptions made about the existence of additional vectors in the subspace.
mathmari
MHB
Hey! :o
Let $1\leq k,m,n\in \mathbb{N}$, $V:=\mathbb{R}^n$ and $U$ a subspace of $V$ with $\dim_{\mathbb{R}}U=m$. Let $u_1, \ldots , u_k\in U$ be linear independent. Show that there are vectors $u_{k+1}, \ldots , u_m\in U$ such that $(u_1, \ldots , u_m)$ is a basis of $U$.
Hint: Use the following two statements. Convince that $\ell:=m-k\geq 0$ and use induction on $\ell$. Statement 1:
Let $1\leq k\in \mathbb{N}$ and $v_1, \ldots v_k, w\in V$.
  1. $1\leq m\in \mathbb{N}$ and $w_1, \ldots , w_m\in V$ such that $\text{Lin}(v_1, \ldots , v_k)=\text{Lin}(w_1, \ldots , w_m)$ then it holds that $\text{Lin}(v_1, \ldots , v_k, w)=\text{Lin}(w_1, \ldots , w_m, w)$.
  2. If the vectors $v_1, \ldots , v_k$ are linear independent and $w\notin \text{Lin}(v_1, \ldots , v_k)$ then also the vectors $v_1, \ldots , v_k, w$ are linear independent.
Statement 2:
Let $U\leq_{R}V$ and $W\leq_{R}V$ such that $W\subseteq U$. Then it holds that $\dim_RW\leq \dim_RU$ and the equality iff $W=U$. So to use Statement 1 we have to show that $u_{k+1}, \ldots , u_m\notin \text{Lin}(u_1, \ldots , u_k)$ and then we apply the Statement 1 using induction or how do we have to start? (Wondering)
Hey mathmari!
If $k=m$ then we are done, aren't we? (Wondering)
So let's assume that $k<m$.
Base case
$(u_1, \ldots , u_k)$ cannot be a basis of $U$ can it?
Because if it were then the dimension of $U$ would be $k$ instead of $m$, and we just assumed that $k<m$.
So there must be a vector $w$ in $U$ that is not an element of the linear span of $(u_1, \ldots , u_k)$, mustn't there?
What we can do with that element? (Thinking)
Base case
From the second part of statement 1 we get that $u_1, \ldots , u_k,w$ are linear independent.
So now we consider the linear span of $(u_1, \ldots , u_k,w)$, or not?
At the base case we have that $\ell=m-k=1$, or not? So we have to add just one vector to get a basis, which is $w$, right? (Wondering)
Yep. (Nod)
Hmm... not sure if we can make it work like that. (Thinking)
I had the idea that for the inductive step we would assume that we could extend the independent set $(u_1, \ldots , u_k)$ to the independent set $(u_1, \ldots , u_\ell)$ with vectors that are all in $U$ and with $k\le \ell < m$. (Thinking)
Yep. (Nod)
So do you mean that at the base case we extend the independent set $(u_1, \ldots , u_k)$ to the independent set $(u_1, \ldots , u_k, w)$ then at the inductive hypothesis we assume that we can extend the independent set $(u_1, \ldots , u_k)$ to the independent set $(u_1, \ldots , u_\ell)$ with $k\le \ell < m$ and at the inductive step we extend the independent set $(u_1, \ldots , u_k)$ to the independent set $(u_1, \ldots , u_m)$ ? (Wondering)
Yep. (Nod)
Shouldn't we extend the independent set $(u_1, \ldots , u_\ell)$ from the induction hypothesis to the independent set $(u_1, \ldots , u_\ell, w)$? (Wondering)
Yep. (Nod)
Is this a strong induction on $\ell$ ? (Wondering)
So we add just one extra vector, right? (Wondering)
Not really. (Shake)
What makes you think so?
Yep. (Nod)
Not really. (Shake)
I thought so because we took $k\le \ell < m$. Could you explain to me further what we assume at the inductive hypothesis? How many vectors to we add to the span? (Wondering)
I was thinking of the following proof by induction. (Thinking)
Base case
The set $(u_1,\ldots,u_\ell)$ with $\ell=k \le m$ is a linearly independent set.
Inductive hypothesis
We can extend the independent set $(u_1,\ldots,u_k)$ to an independent set $(u_1,\ldots,u_\ell)$ with all vectors in $U$ and with $k\le\ell\le m$.
Inductive step
If $\ell = m$ we are done as we have the desired set of vectors.
Otherwise $\ell<m$ so there must be a vector $w\in U$ that is not in the linear span of $(u_1,\ldots,u_\ell)$, since the dimension of $U$ is greater than $\ell$.
So we can take $u_{\ell+1}=w$ and $(u_1,\ldots,u_\ell,u_{\ell+1})$ is then an independent set with all vectors in $U$ and with $k\le\ell+1\le m$.
The fact that we can keep extending the independent set until $\ell=m$ completes the proof. (Emo)
Note that we take only 1 step at a time, and in particular we do not use that $(u_1,\ldots,u_{\tilde\ell})$ with $k\le\tilde\ell<\ell$ is an independent set, which would otherwise make it strong induction. (Nerd)
  • · Replies 24 ·
  • · Replies 23 ·
  • · Replies 25 ·
