Show that two polynomials cannot span P2.
  • Level: Undergrad
  • Thread starter Thread starter kingkong69
    Polynomials Span
3 replies · 6K views
kingkong69
Hi
I know the dimension is 3, two polynomials has dimension 2 only so it cannot span P2.
How would I go about showing it if I were to write it down mathematically?
Thanks
kingkong69 said:
Hi
Thanks
Do you mean P2 is the space of all polynomials (over some field, say) of degree less than or equal to 2?
Well, take two such pol's [itex]ax^2+bx+c\,\,,\,\,a'x^2+b'x+c'\,\,[/itex] , with a,b,c,a',b',c' elements of the field, and show that
[itex]\alpha(ax^2+bx+c)+\beta(a'x^2+b'x+c')\,\,,\,\, \alpha \,,\,\beta \,\,[/itex] in the field, cannot possibly give all the elements of [itex]P_2[/itex]...
DonAntonio
Hi
thanks i get u.
i have a question for you.
when I am given a set of vectors, i am asked to find a basis for it.
I solve it to Reduced row echolon form and get the basis.
But sometimes i have to write the vectors in columns, sometimes in rows for the matrice.
Sorry for being unclear
Do i need to check if the vectors are linearly independent in column space form? and then apply it in row space if they are dependent?
Thanks DonAntonio
kingkong69 said:
Hi
thanks i get u.
*** I'm guessing you actually mean that you have to find a basis for the space generated by that given set of vectors...right? ***
*** Once again, I'm guessing you mean you write every polynomial as a row or column vector (it never matters, believe me) and then you
form a matrix with those rows (vectors) and then you reduce it...right? ***
It doesn't matter rows or columns: it'sjust the same at the end.
DonAntonio
