Show the proof involving multiples of numbers
  • Thread starter Thread starter chwala
    Numbers Proof
The discussion centers around proving that the sum of four consecutive multiples of 4 is always a multiple of 8. Participants are exploring algebraic expressions and the properties of multiples in this context.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the algebraic representation of the problem, questioning the use of variables and the interpretation of multiples. Some suggest additional steps to clarify the proof, while others explore the implications of using different variable names.
The discussion is active, with various interpretations being explored. Some participants have offered guidance on how to approach the proof, while others are questioning assumptions and definitions related to the problem.
There are mentions of potential misunderstandings regarding the definitions of multiples and the relevance of certain algebraic expressions. Participants also note the importance of clarity in variable naming when discussing mathematical proofs.
chwala
Prove that the sum of four consecutive multiples of ##4## is always a multiple of ##8##
algebra
Let the first multiple of ##4=x##, then it follows that;
##x+(x+4)+(x+8)+(x+12)=4x+24=4(x+6)## ...where ##4## is a multiple of ##8##
Eh?
  • Love
chwala said:
Homework Statement:: Prove that the sum of four consecutive multiples of ##4## is always a multiple of ##8##
Relevant Equations:: algebra
Let me do some research on this ...
Hi @chwala! .
4 is not a multiple 8 (instead 8 is a multiple 4)
Your proof needs 1 more final little step. you got to factor an additional factor of 2 out of ##4(x+6)## so u have ##4\cdot 2 (...+...)=8(...+...)## so it is obvious it is a multiple of 8. Got any ideas?
The original problem is equivalent to the sum of any four consecutive integers being even.
Thanks I will look at this later...
Your interpretation of the problem statement is incorrect. Four consecutive multiples of 4 would be ##k \cdot 4, (k+1) \cdot 4, (k+2) \cdot 4, (k+3) \cdot 4##.
Also, if there aren't any relevant equations, just leave that section empty rather than putting in something that is meaningless. "Algebra" is not relevant, let alone being an equation.
Mark44 said:
Your interpretation of the problem statement is incorrect. Four consecutive multiples of 4 would be k⋅4,(k+1)⋅4,(k+2)⋅4,(k+3)⋅4.
No I don't think its incorrect, it is the same as yours with ##x=4k##. He just names it x instead of 4k.
Fair enough -- I didn't read the post that carefully.
  • Love
Delta2 said:
Hi @chwala! .
Would that be;
##4\cdot 2(\dfrac{x}{2}+3)=8(\dfrac{x}{2}+3)?## Where ##x## will always divide ##2##...or ##2## will always be divisible by ##x.##
chwala said:
Would that be;
I've no idea why you are using ##x## for a multiple of four, and then never use this fact explicitly.
chwala said:
Would that be;
yes, but you want to say that 2 divides x (because x is a multiple of 4 and 2 divides 4).
Well x is a multiple of 2 was used
x is a multiple of 4 is not needed
How can you "like" a post that says that 2 will always be divisible by a multiple of 4?
In any case, the OP should be using ##4k## and not ##x## when dealing with an arbitrary multiple of 4. That's just basic, good technique.
  • Love
PeroK said:
How can you "like" a post that says that 2 will always be divisible by a multiple of 4?In any case, the OP should be using ##4k## and not ##x## when dealing with an arbitrary power of 4. That's just basic, good technique.
Noted @PeroK ...thanks for pointing that out.
E hehe typo police here, you mean arbitrary multiple of 4, not power.
PeroK said:
How can you "like" a post that says that 2 will always be divisible by a multiple of 4?In any case, the OP should be using ##4k## and not ##x## when dealing with an arbitrary multiple of 4. That's just basic, good technique.
I liked it because I liked it. Sometimes I like things that are not perfect. Clearly a simple typo. We all make them. Naming variables conveniently not a the most important technique, but is helpful at times. 4x,4x+4,4x+8,4x+12 is nice I would probably use x-6,x-2,x+2,x+6 instead but it does not matter. Often you would not realize the desired form until after naming the variables. Sure you could then edit your work to appear psychic, but why bother.
PeroK said:
In any case, the OP should be using 4k and not x when dealing with an arbitrary multiple of 4. That's just basic, good technique.
For me, doing this is a result of standing in front of a math classroom for many years, trying to make things as self-explanatory as possible. IOW, trying to follow the Principle of Least Astonishment.
This may be a roundabout way. You have a general expression for the sum of 4 terms in an AP (Arithmetic Progression) , with r=4.
When would this sum 4(x+6) be a multiple of 8?
You need a multiple of 2 here, since you already have a 4 available. So you could prove something stronger, of when such a sum is a multiple of 8, and conclude it's true for x a multiple of 4.
I had initially thought of using this approach of finding sum...i will look at this and get back by weekend...
  • · Replies 21 ·
  • · Replies 21 ·
  • · Replies 20 ·
