Finding a Vector Perpendicular to the Line of Reflection
  • Context: MHB
  • Thread starter Thread starter mathmari
    Properties
The discussion focuses on the mathematical properties of the reflection map defined as $$\sigma_x:\mathbb{R}^n\rightarrow \mathbb{R}^n, \ v\mapsto v-2\frac{x\cdot v}{x\cdot x}x$$ for a non-zero vector $x$ in $\mathbb{R}^n$. Participants confirm that $\sigma_x$ is a linear transformation, belongs to the symmetry group of $\mathbb{R}^n$, and is its own inverse. They also explore the relationship between the reflection map and vectors along and perpendicular to the line of reflection, particularly in $\mathbb{R}^2$, where they identify $(\cos a, \sin a)$ as a directional vector along the line and seek a perpendicular vector.
  • Understanding of linear transformations and their properties
  • Familiarity with vector operations in $\mathbb{R}^n$
  • Knowledge of symmetry groups in mathematics
  • Basic trigonometry, particularly in relation to angles and directional vectors
  • Study the properties of linear transformations in detail
  • Learn about symmetry groups and their applications in geometry
  • Explore the concept of reflection in linear algebra
  • Investigate the relationship between angles and directional vectors in $\mathbb{R}^2$
Mathematicians, students studying linear algebra, and anyone interested in geometric transformations and their properties.
mathmari
MHB
Hey! :o
Let $1\leq n\in \mathbb{N}$. For $0_{\mathbb{R}^n}\neq x\in \mathbb{R}^n$ we define the map $$\sigma_x:\mathbb{R}^n\rightarrow \mathbb{R}^n, \ v\mapsto v-2\frac{x\cdot v}{x\cdot x}x$$
Show that:
  1. The map is linear.
  2. It holds that $\sigma_x\in \text{Sym}(\mathbb{R}^n)$ and $\sigma_x=\sigma_x^{-1}$.
  3. For all $v,w\in \mathbb{R}$ it holds that $v\cdot w=\sigma_x(v)\cdot \sigma_x(w)$.
  4. Let $n=2$. Determine a vector $v\in \mathbb{R}^2$ such that $\sigma_v=\sigma_a$, where $\sigma_a$ is
    the reflection on the straight line through the origin, where $a$ describes the angle between the straight line and the positive $x$-axis.
I have done the following:
  1. $\sigma_x$ is additive:
    \begin{align*}\sigma_x(v+w)&=(v+w)-2\frac{x\cdot (v+w)}{x\cdot x}x=(v+w)-2\frac{\sum_{i=1}^nx_i\cdot (v+w)_i}{x\cdot x}x\\ & =(v+w)-2\frac{\sum_{i=1}^nx_i\cdot v_i+\sum_{i=1}^nx_i\cdot w_i}{x\cdot x}x=(v+w)-2\left(\frac{\sum_{i=1}^nx_i\cdot v_i}{x\cdot x}+\frac{\sum_{i=1}^nx_i\cdot w_i}{x\cdot x}\right )x \\ & =(v+w)-2\frac{\sum_{i=1}^nx_i\cdot v_i}{x\cdot x}x-2\frac{\sum_{i=1}^nx_i\cdot w_i}{x\cdot x}x=v-2\frac{\sum_{i=1}^nx_i\cdot v_i}{x\cdot x}x+w-2\frac{\sum_{i=1}^nx_i\cdot w_i}{x\cdot x}x \\ & = \sigma_x(v)+\sigma_x(w)\end{align*}
    $\sigma_x$ is homogeneous:
    \begin{align*}\sigma_x(rv)&=(rv)-2\frac{x\cdot (rv)}{x\cdot x}x=rv-2\frac{\sum_{i=1}^nx_i\cdot (rv)_i}{x\cdot x}x\\ & =rv-r2\frac{\sum_{i=1}^nx_i\cdot v_i}{x\cdot x}x=r\left (v-2\frac{\sum_{i=1}^nx_i\cdot v_i}{x\cdot x}\right ) \\ & = r\sigma_x(v)\end{align*}
    Therefore the map $\sigma_x$ is linear.
  2. Could you give me a hint how we can show that? (Wondering)
  3. \begin{align*}\sigma_x(v)\cdot \sigma_x(w)&=\left (v-2\frac{x\cdot v}{x\cdot x}x\right )\cdot \left (w-2\frac{x\cdot w}{x\cdot x}x\right )=v\cdot w -2\frac{x\cdot w}{x\cdot x}v\cdot x-2\frac{x\cdot v}{x\cdot x}w\cdot x+4\frac{x\cdot v}{x\cdot x}\frac{x\cdot w}{x\cdot x}x\cdot x \\ & =v\cdot w -2\frac{(x\cdot w)(v\cdot x)}{x\cdot x}-2\frac{(x\cdot v)(w\cdot x)}{x\cdot x}+4\frac{(x\cdot v)(x\cdot w)}{x\cdot x}=v\cdot w -4\frac{(x\cdot w)(v\cdot x)}{x\cdot x}+4\frac{(x\cdot v)(x\cdot w)}{x\cdot x}\\ & =v\cdot w\end{align*}
  4. How can we find such a vector? Do we use the matrix of the map of $\sigma_a$ ? (Wondering)
mathmari said:
Hey! :o
Show that:
Hey mathmari!
The symmetry group is the group of bijections from a set to the same set.
Is it a bijection? (Wondering)
mathmari said:
3. How can we find such a vector? Do we use the matrix of the map of $\sigma_a$ ?
Suppose $\sigma_x$ is a projection. What would be a vector along its line of reflection?
And what would be a vector perpendicular to its line of reflection? (Wondering)
Do we check that using the definitions? As we do that when we consider functions? (Wondering)
The one will be the vector x and the other the vector v? (Wondering)
Suppose we verify that $\sigma_x(\sigma_x)=\operatorname{id}$.
Then that proves that $\sigma_x^{-1}=\sigma_x$ doesn't it? (Wondering)
And additionally it proves that $\sigma_x$ is invertible, which implies it is bijective, doesn't it? (Wondering)
Isn't $v$ the parameter to the function?
It's not a constant vector, is it? (Worried)
Which one is the vector $x$? (Wondering)
Knowing that the map is invertible do we know that the map is bijective or injective? (Wondering)
I haven't understood that part. Could you explain it further to me? (Wondering)
Do we have any propositions or some such saying so? (Wondering)
Or can we prove it?
That is, can we prove that $\sigma_x$ is both injective and surjective given that it is invertible? (Wondering)
We have the map $\sigma_x$ and it is given by a formula of the form $\sigma_x:v\mapsto \sigma_x(v)$.
In this formula $x$ is a fixed vector.
And $v$ is an arbitrary vector that is mapped to a vector in the image. In particular $v$ is not a fixed vector. (Nerd)
Assuming the $\sigma_x$ is a reflection in $\mathbb R^2$, there must be a vector $n$ normal to the line of reflection such that $\sigma_x(n)=-n$, mustn't it?
And there must be a directional vector $d$ along the line of reflection, such that $\sigma_x(d)=d$, which is a fixpoint. (Thinking)
Is $x$ a normal vector to the line of reflection, or is it a directional vector along the line of reflection? (Wondering)
$x$ is a directional vector along the line of reflection, or not? (Wondering)
Do we have $\sigma_x(x)=x$?
What is $\sigma_x(x)$? (Wondering)
We have that $\sigma_x(x)=x-2\frac{x\cdot x}{x\cdot x}x=x-2x=-x$.
That means that $x$ is a normal vector to the line of reflection, right? (Blush)
Yep. (Nod)
Yep. (Nod)
Ok! Can we get a specific vector? Maybe using the matrix of map $\sigma_a$ ? (Wondering)
The question only asks for a fixed vector.
We know now that we need a vector perpendicular to the line of reflection.
The line has an angle a with respect to the positive x-axis.
So $(\cos a,\,\sin a)$ is a directional vector along the line.
Can we find a vector perpendicular to it? (Wondering)
  • · Replies 26 ·
  • · Replies 0 ·
  • · Replies 52 ·
  • · Replies 23 ·
  • · Replies 27 ·
