Undergrad Showing direct sum of subspaces equals vector space
To show that R^3 equals the direct sum of subspaces U and V, it is necessary to demonstrate that R^3 = U + V and that U ∩ V = {0}. The discussion emphasizes the importance of expressing an arbitrary point in R^3 as a sum of vectors from U and V, specifically using the forms of vectors in each subspace. The participants suggest solving the equation for arbitrary points in R^3 to find appropriate values for r, s, and t that satisfy the conditions. Ultimately, confirming the dimensions of U and V can also provide a straightforward proof of the direct sum relationship.
schniefen
TL;DR
Consider ##U=\{\textbf{x} \in \mathbf{R}^3; x_1+x_2+3x_3=0\}## and ##U=\{t(1,1,2)\in\mathbf{R}^3; t \in \mathbf{R}\}##. Show that ##\mathbf{R}^3=U \bigoplus V##.
If one shows that ##U\cap V=\{\textbf{0}\}##, which is easily shown, would that also imply ##\mathbf{R}^3=U \bigoplus V##? Or does one need to show that ##\mathbf{R}^3=U+V##? If yes, how? By defining say ##x_1'=x_1+t,x_2'=x_2+t,x_3'=x_3+2t## and hence any ##\textbf{x}=(x_1',x_2',x_3') \in \mathbf{R}^3## can be expressed as a sum of ##\textbf{u}=(x_1,x_2,x_3) \in U## and ##\textbf{v}=(t,t,2t) \in V## for ##t \in \mathbf{R}##?
If ##U\cap V =\{\,0\,\}## then we have a plane and a straight outside the plane, so they have to span a three dimensional space. So whether this is sufficient or not has to be answered by your teacher. I guess you should show that the sum equals the total space for practicing reasons.
In your proof, I don't see why ##\mathbf{u} \in U##. You need to set ##x_3=-\dfrac{1}{3}(x_1+x_2)## and show that the system can be solved.
Solving the system one can write ##\mathbf{u}=(-r-3s, r, s) \in U## for ##r,s\in \mathbf{R}##.
How would one do that? Finding the basis vectors for ##U## and ##V## respectively and check if they are linearly independent? Or can one, less rigorously, state that ##\mathbf{u}=(-r-3s, r, s) \in U## and ##\mathbf{v}=(t,t,2t) \in V## for ##r,s,t\in\mathbf{R}##. Since ##\mathbf{u}+\mathbf{v}=(-r-3s+t,r+t,s+2t)##, every ##\mathbf{x}\in\mathbf{R}^3## can be expressed as a sum of ##\mathbf{u}+\mathbf{v}## by choosing appropriate constants.
You have to solve the equation ##\mathbb{R}^3 \ni (x_1,x_2,x_3)= \mathbf{u} + \mathbf{v}## where ##\mathbf{u} \in U, \mathbf{v} \in V## have to be expressed in terms of the ##x_i\,.## Yes the elements of ##U## look like ##(-r-3s,r,s)## and the elements of ##V## as ##(t,t,2t)##, but what are ##r,s,t## given an arbitrary point ##(x_1,x_2,x_3)\,?##
This would show ##\mathbb{R}^3=U+V## and with ##U\cap V= \{\,0\,\}## we get ##\mathbb{R}^3
=U\oplus V##. Of course the dimension argument would give the result immediately, as I first said. The presentation of an arbitrary point as a sum of vectors ##\mathbf{u},\mathbf{v}## is just for practice.
Likes schniefen
Thread 'How to define a vector field?'
Hello! In one book I saw that function ##V## of 3 variables ##V_x, V_y, V_z## (vector field in 3D) can be decomposed in a Taylor series without higher-order terms (partial derivative of second power and higher) at point ##(0,0,0)## such way: I think so: higher-order terms can be neglected because partial derivative of second power and higher are equal to 0. Is this true? And how to define vector field correctly for this case? (In the book I found nothing and my attempt was wrong...
  • · Replies 0 ·
  • · Replies 25 ·
  • · Replies 21 ·
