Showing isomorphism between fractions and a quotient ring
1 reply · 2K views
Mr Davis 97
For a commutative ring ##R## with ##1\neq 0## and a nonzerodivisor ##r \in R##, let ##S## be the set
##S=\{r^n\mid n\in \mathbb{Z}, n\geq 0\}## and denote ##S^{-1}R=R\left[\frac{1}{r}\right]##.
Prove that there is a ring isomorphism $$R\left[\frac{1}{r}\right]\cong \frac{R[x]}{(rx -1)}.$$
Let ##\phi : R[x] \to R\left[ \frac{1}{r} \right]## such that ##\phi(p(x)) = p(\frac{1}{r})##. This is a homomorphism since it is the evaluation homomorphism. Let ##a\in R## and ##k\in \mathbb{N}##, then ##\phi(ax^k) = \frac{a}{r^k}##, and the latter is a general element of ##R\left[ \frac{1}{r} \right]##. Now, we will show that ##\ker (\phi) = (rx-1)##. The "##\supseteq##" direction is clear, since if ##a\in (rx-1)##, then for some ##g(x)\in R[x]##, ##a=g(x)(rx-1)##. Then $$\phi(g(x)(rx-1)) = \phi(g(x))\phi(rx-1) = \phi(g(x))(r\cdot \frac{1}{r} - 1) = \phi(g(x))\cdot 0 = 0.$$
The "##\subseteq##" direction is where I get confused. If the underlying ring were a field I could use the division algorithm, but since it is not I am not sure what to do.
I haven't done it (a bit late here), but I assume it is something like:
Let ##p(x)=a_n+a_{n-1}x+\ldots +a_1x^{n-1}+a_0x^n \in \operatorname{ker} \phi\,.## Then ##a_nr^n+a_{n-1}r^{n-1}+\ldots +a_1r+a_0 = 0##. So ##a_0=r\cdot b_0## and ##0=r\cdot \left(a_nr^{n-1}+\ldots +(a_1+b_0) \right)## and because ##r## isn't a zerodivisor ##0=a_nr^{n-1}+a_{n-1}r^{n-2}+\ldots +a_2r +b_1\,.##
Now it looks as if a minimal ##n=\operatorname{deg}(p)## argument or an "and so on" could apply so we get either ##n=1## or ##n=0##.
