Showing that d²(v²)/dt² = 2g² for projectile motion
14 replies · 2K views
Klaz
Show that for a projectile d^2 (v^2)/dt^2 = 2g^2
Since we are only dealing with the y component for this. 2nd derivative would be 2. But since gravity acts on it then d^2 (v^2)/dt^2 = 2g. I don't get how to get to 2g^2. Can someone help me please.
Start with a general expression for the vertical velocity of a projectile.
Doc Al said:
Step by step. What's the first derivative of v^2?
First derivative would be 2v.
Vertical velocity = v - at. I am still confuse on what to do with this equation. Since dv/dt = a.
If Vy=v^2-gt then the first would be dv/dt = 2v-g.
That's not complete. In that equation v is a function of time, so apply the chain rule.
that would be ##v = v_o - g t##. Square both sides so that you have an expression for v2. Then do your derivatives. Remember that dv/dt = g.
I don't know where you got that expression for Vy. It's not correct.
It's your maths that's letting you down here. I don't think you understand what is being asked. You are asked to differentiate ##v^2##. Not ##v##.
I would first work out what ##v^2## is. That seems logical to me: you are asked to differentiate ##v^2##, with respect to time (twice). So, let's first have ##v^2## as a function of ##t##.
##v^2 = \dots ##
Can you do that?
As gneill already pointed out, that is not complete.
What you found is the first derivative with respect to v. But what you need is the first derivative with respect to t. So, keep going. (Think chain rule.)
If I apply chain rule. Let u=(v-gt)^1/2. Then : dv/dt = (u)^1/2
dv/dt = du/dt × dv/du = -g/2 (v-gt)^1/2. Am I on the right track? Then my next step would be to differentiate my answer again.
Why not start with what you were given?
Let u = v^2
du/dt = du/dv * dv/dt.
Hint: What is dv/dt for a projectile?
Let u = v^2
du/dt = 2v * -g = -2vg.
2nd derivative:
du/dt = -2g * - g = 2g^2.
Thank you. Can I ask one more question. What is wrong with my first attempt using the chain rule? Can i still get the same answer if I kept going with my solution?
I couldn't follow what you were trying to do.
Klaz said:
Let u=(v-gt)^1/2
Where did you get this?
Perhaps you meant to follow gneill's advice:
gneill said:
that would be ##v = v_o - g t##. Square both sides so that you have an expression for ##v^2##.
You can try that again and you should get the same answer.
Doc Al said:
I couldn't follow what you were trying to do.Where did you get this?
Yes I followed his advice. I'll give it one more try using that. Thank you.
