Significance of current gain in transistors
The discussion centers on the significance of current gain in transistors, highlighting that low power transistors (under 1 W) typically exhibit a current gain of 100 to 300, while high power transistors (over 1 W) have a current gain of 20 to 100. This difference is attributed to the larger base width in power transistors, which leads to increased recombination and lower current gain. The conversation also emphasizes the role of transistors in amplifying small signals from devices like microphones and sensors, allowing for effective control of collector current through base current manipulation.
  • Understanding of transistor operation principles
  • Familiarity with current gain concepts in electronics
  • Knowledge of amplifier design basics
  • Awareness of signal amplification techniques
  • Research the impact of base width on current gain in power transistors
  • Explore the relationship between recombination and bandwidth in transistors
  • Learn about different types of amplifiers and their applications
  • Investigate the role of transistors in signal processing for various sensors
Electronics engineers, students studying semiconductor physics, audio engineers, and anyone involved in designing or working with amplification circuits.
shauns87
"For low power transistors (under 1 W), the current gain is typically 100 to 300. High power transistors (over 1 W) usually have current gain of 20 to 100." — Electronic principles by Malvino
I want to understand why the current gain is high for low power transistors and why it is low for high power transistors.
Besides, I want to know that why we are trying to control the collector current by the base current. What do we get out of controlling these currents.
In power transistors the base width is larger than in signal transistors, hence higher recombination and lower current gain.
But, why higher recombination required for higher bandwidth?
Many useful devices we use produce quite small voltages and currents.
A microphone may produce only 10 mV AC output which would be inaudible if it was connected directly to a speaker.
Using transistors, we can get this small current to vary a base current which controls a much bigger collector current.
This can then be used to control the base current of another transisitor and so on until the signal becomes large enough.
Without going much deeper into amplifier design, you can probably see that this process could produce a very loud signal from a very small one.
There are other sensors that produce very small outputs which need to be amplified before they are of any use.
There are thermisters for monitoring temperatures, photodiodes and light dependent resistors for measuring light and even ECG sensors that doctors attach to your body to measure the extremely small voltages produced when your heart beats.
All of these need amplifying and using them to control the base current of transistors is one way of doing this.
Wow, that was great! Absolutely, I got it now.
It is the inverse. Low power transistors have less recombination and higher bandwith.
A higher recombination is a consequence of the larger base junctions width. The larger width is necessary for higher heat dissipation.
Voltage source with resistor in series = current source with the same resistor in parallel?
Could you please help me understand the explanation behind connecting the resistor in parallel and not in series for transforming the voltage source into the current source?
  • · Replies 49 ·
