Significant Figures with Kinetic Energy Formula?
5 replies · 4K views · last reply
ProfessorMadMan
An object of mass m = 2.3±0.1 kg is moving at a speed of v = 1.25±0.03 m/s. Calculate the kinetic energy (K = 1 /2mv2 ) of the object. What is the uncertainty in K?
I am not exactly sure if I used the error equation correctly when I start using Δ(v2). Could someone verify my logic here?
K=0.5mv2
Δ(v2)=nx^(n-1)(Δx)
ΔK=(k )(z(Δm/m +(Δv2)/(v2))), k=0.5, z=1.8
K=0.5mv2=0.5(2.3kg)(1.25m/s)2=1.8J
Power Error Equation
Δ(v2)=nx^(n-1)(Δx)
=2(1.25)^1(0.03)
Δ(v2)=0.075
Multiplication and Constant Error Equation
K = 0.5 ⋅ 1.8 ⋅((0.1/2.3)+(0.075/1.252))
K = 0.08
Where did the 0.5 come from?
An easy way to check your answer is to plug in the values that would make K its max: 1.25+0.03, 2.3+0.1.
Sorry this was meant to be K = 0.5 ⋅ 1.8 ⋅((0.1/2.3)+(0.075/1.252)), is that still correct?
The 0.5 comes from the K=1/2 mv2
I understand that the 0.5 is an exact number, but my thought is that the uncertainty that I am calculating here needs to be scaled ( or with the same ratio) after you put the uncertainty with mass and speed given in the beginning through the KE formula. OR does that not matter?
I am using the exact constant rule: z = k Δx, whereas k has no uncertainty, or Δk=0. So I use 0.5 from the kinetic energy formula as k.
K=0.5mv2
Δ(v2)=nx^(n-1)(Δx)
In general, Δ(xn) = nxn−1(Δx) .
Specifically, Δ(v2) = 2v1(Δv) .
You already included that when calculating the 1.8J.
