Significant Figures: Why Leading Zeros Don't Count
  • Context: High School
  • Thread starter Thread starter RaduAndrei
    Significant figures
This discussion centers on the concept of significant figures and their relationship to measurement precision. It highlights that leading zeros are not counted as significant figures, which results in different significant figure counts for values like 8.84 V (three significant figures) and 0.01 V (one significant figure). The conversation also emphasizes that while precision refers to the number of decimal points a measurement can achieve, significant figures indicate the reliability of those measurements, particularly when comparing values of vastly different magnitudes.
  • Understanding of significant figures in measurements
  • Knowledge of precision and accuracy in scientific instruments
  • Familiarity with relative and absolute error concepts
  • Basic grasp of logarithmic functions and their application in error analysis
  • Explore the concept of "absolute error" in measurement techniques
  • Learn about the role of precision in scientific instrumentation
  • Investigate how to calculate significant figures in various measurement scenarios
  • Study the implications of measurement uncertainty in scientific reporting
Students, educators, and professionals in scientific fields who require a clear understanding of measurement accuracy, precision, and significant figures in their work.
RaduAndrei
I measure some quantity with an instrument that it is precise to two decimal points.
So maybe I get 8.84 V. Then I do some changes in my parameters and get 0.01 V.
The two measured values are precise to two decimal points. But the first one has three significant figures, while the second one has only one significant figure.
Why is that? Should not both of them have the same number of significant figures?
Why are the leading zeros not considered significant?
Significant figures are a way of dealing with "relative error". That is, error as a fraction of the actual value.
If the actual value is smaller, the relative error is larger.
How many "leading" zeroes can you write?
For a particular unit that I chose and is Volts, only two leading zeros.
But what is the connection of significant figures to the precision? By precision I mean the number of decimal points to which a measured value is known. For ex, a precision of 0.1 or 0.01.
And what if you chose millivolts? Or kilovolts?
8.84 in mV would be 8850 and 0.01 in mV would be 10.
So 3 significant figures vs 1 significant figure. The 0 at the end should not count.
That's the thing. I do not get the connection between significant figures and the precision. An instrument with a certain precision (two decimal points for a particular unit) gives of two numbers with different number of significant figures. Or maybe there is a connection for numbers larger than 1 and another connection for numbers between 0 and 1.
log(value/error).
jbriggs444 said:
log(value/error).
Value being the true value or measured value? Error being the relative error or absolute error? And log(value/error) representing what?
As long as the absolute error is small compared to the the true value (or to the measured value) then it does not matter which.
The absolute error. For instance, if the accuracy of the measuring device is +/- .001 then the error is .001.
If you know what the value is and what the error is, what do you think the log(value/error) is?
Maybe the connection is this.
Let's say we have an instrument which has a precision of 2 decimal points for a particular unit V.
Then the number of significant figures can be: 3 for numbers of the form 4.55, 2 for numbers of the form 0.85, 1 for numbers of the form 0.03. That's it if the numbers are below 10. And if the the numbers can be whatever, then the number of significant figures can be from 1 to n, whatever n is.
So a significant figure is a digit that adds to the precision, but I thought there was a connection between the number of decimal points and number of significant figures. Anyway.
What does this mean? What numbers and what n are supposed to be whatever?
The numbers being the measured values. If the measured value if 88.85 then I have 4 sign figures.
For 4544.34 I have 6 sign figures.
The precision is always at two decimal points, but the number of signif figures can be from 1 to n depending on what the measured value is.
The number of significant figures? The integer part at least plus 1.
Again, what is "n" supposed to denote?
The number of significant figures.
So it is your position that the number of significant figures can range from one to the number of significant figures.
Yes. n can vary from 1 to whatever.
I understand that it is a mistake to say that x can vary from 1 to x. But you got my point.
If n is the number of significant figures then the number of significant figures is n. But that statement tells no one anything about what the number of significant figures is.
I do not get where you are going with this.
Re-read what you have written about n and see if there is any sense to be made of it.
I think I can translate--tell me if I'm wrong:
Teachers say that the number of sig figs represents the precision of the instrument, however the OP has found a situation in which that does not make sense: you measure the mass of something to be 4.329 kg (4 sig figs). The same device measures something far more massive and comes up with 563214903.271 kg (12 sig figs). The teacher's definition of precision seems to fail; a device measures two different masses with the same precision, but gets answers with drastically different amounts of sig figs. Both times the device measures to the nearest gram, but the second object is about 8 orders of magnitude larger than the first object, so the result has 8 more sig figs.
I believe the answer to this is that sig figs don't really have any thing to do with precision, it's all in the number of known decimals. Is that correct?
Also, look at post number 2 again. @jbriggs444 explains what sig figs actually do; show relative error.
Anecdote: Way back when, in my first year at the University, we had a crash course in measurements and error estimates. The favorite story of the lecturer dealt with a new world record in javelin throw. The American Bud Held had thrown the javelin 263 feet 10 inches - and a journalist had converted that to metric measures (this was before the inch was standardized to 25.4mm) and come up with a result of 80.41754m.
His point was: A grain of sand is about 1mm in diameter or 0.001m. The mark left by a javelin when it lands (usually in a grass field) is at least 4inches long. Thus, 263 feet 10 inches indicates a measurement precision of about one inch - which is reasonable. Translated to metric it indicates a precision of about 2.5cm. So - the journalist invented a precision that was not present in the original measurement.
A digital instrument has a resolution and a precision. The usual digital multimeter has a precision of 3½ digits or about 1/1000 - which tells us something about the analog part of the meter. The resolution is the "step size" of the digital part of the meter. 1/1000 is the equivalent of 10 bits - and an analog-to-digital converter with 12 bit resolution is basic technology. Thus you can get a measurement with lots of figures, not all of which have any significance.
Anecdote: When digital thermometers first came out, they had a tendency to show the temperature with at least two decimals (as in 17.65°C). That represented the resolution of the digital part of the thermometer. Just for fun I checked it against a calibrated mercury thermometer and got a calibrated reading of about 1°C higher. The precision of the mercury thermometer was 0.25°C, so the precision of the digital thermometer was about 1°C. The decimals given by the digital thermometer were useless. Decide for yourself whether or not they were significant figures.
That is right. So the number of sig figures do not represent the precision, they just add to the precision.
There is sense. I just did not say it formally. It is a simple idea. No need to be pedantic.
No, they do not add to the precision.
If the larger mass is measured with 12 significant figures - a precision of one part in 1012, I would like to see the measuring device!
So. In a book it says:
"The uncertainty is just an estimate and it should not be stated with too much precision. For example, instead of saying g = 9.82 +/- 0.02385 m/s2, we should say g = 9.82 +/- 0.02 m/s2 because you cannot know the uncertainty to four significant figures. As a rule, experimental uncertainties should almost always be rounded to one significant figure"
So observe that the author talks about precision and significant figures as they are related and I too believe that. Many authors seem to play with this word precision while talking about significant figures.
What I am asking here is what is the connection between them two more precisely. I know that the precision refers to the repeatability of a measurement. For example, if I measure 4.54, 4.56, 4.55, etc, then I can say that I have a precision of 0.01. And the number of significant figures is 3. If the precision were to be 0.001 then the number of significant figures would have been 4.
It seems to me that the significant figures add to the precision of a measurement. Or I can say that the precision represents the number of significant figures in the decimal places. Exception can be like 0.005, 0.004, etc There is only one significant figure here while the precision is 0.001. But if the precision increases then the number of sign figures also increases. So I can safely say that the significant figures add to the precision of a measurement and just that.
Am I wrong?
Significant figures do not add to precision. They express the precision in a different way.
I am not saying 'add' in the way that I actually add the number of significant figures with the precision. I'm saying it in a figuratively way.
The more significant figures you have in the decimal places, the more precision you have.
Or is this wrong?
15K
  • · Replies 25 ·
