Similar triangles with side length 10
  • Thread starter xzibition8612
    Triangle
xzibition8612
see attachment
No idea how to do this. Tried extending the 10 thus getting a big triangle of (10+x)^2+y^2=400. But then again no idea what x and y is. This is wrong. Any help would be appreciated.
  • Triangle with vertices at lower left, lower right and upper right; side lengths labelled 20 (upper left), 10 (bottom), 5 and 12 (right side, with a small right-angle marker) and ??? on the right.
xzibition8612 said:
see attachment
If you understand what the term 'similar triangles' means, it should be obvious that the two triangles in your sketch are NOT similar.
If the problems isn't merely to determine whether the triagles are similar, please provide a complete problem statement.
The question is how do i find the length of the unknown side (?). The figure is all I'm given. Any idea? I thought about extending the bottom (length 10) and thus making the entire triangle a right triangle and using that with 5-12 relationship of the slope of the unknown side, but not sure how to do this. any law of sin or cos that's applicable hhere?
I cannot see that the ? attaches to any particular line, but there are TWO lines that it MIGHT attach to.
EDIT: Oh, I see. It's really trivial. Do you know the pathagorean theorem? Starting hint --- extend the 5/12 triangle and you'll have a single right triangle that can be solved for it's sides and then go from there.
i figured it out. the length is 10-13.9-20. I used the law of cosines.
That doesn't make any sense. The length has to be positive, and what you show is a negative number.
