EastWindBreaks
- 128
- 3
The discussion centers on the calculation of pitch circle diameter (PCD) for gear systems, specifically addressing a potential typo in homework equations. The correct formula for PCD is established as D = pN/π, where p is the number of teeth and N is the rotational speed. Using π as 3.142 yields a PCD of 302.36 mm, while using a more precise value of π results in 302.394 mm. Additionally, the conversation touches on gear ratios, noting that single-stage spur gears typically have a ratio limit of around 10, with practical constraints on the number of teeth.
PREREQUISITESMechanical engineers, students studying gear systems, and anyone involved in mechanical design and analysis will benefit from this discussion.
the new exact d1 should be T1*Pc/pi, correct? but it has only Pc/T1CWatters said:The used a slightly different value for pi. Probably 3.142
thank you, i probably can't trust my professor's lecture notes anymore...CWatters said:Yes their equation appears to be wrong.
https://en.m.wikipedia.org/wiki/List_of_gear_nomenclature#Standard_pitch_diameter
D=pN/pi
= 25*38/3.142
= 302.36
Or if you use pi to more decimal places you get your answer of 302.394
gear ratio can not be greater than 10 correct?CWatters said:Yes their equation appears to be wrong.
D=pN/pi
= 25*38/3.142
= 302.36
