What is the Tension in Each String for a Hanging Ball?
  • Thread starter Thread starter dolerka
    Tension
The discussion centers on calculating the tension in two strings supporting a ball of mass 0.850 kg, with angles of 30 degrees and 45 degrees relative to the ceiling. The weight of the ball is determined to be 8.33 N. Initial calculations yielded a tension of 6.10 N for String 1, but a miscalculation in the equations led to an incorrect value of 4.31 N for String 2. Correct equations for equilibrium were identified, emphasizing the need to properly resolve the components of tension forces.
  • Understanding of Newton's laws of motion
  • Knowledge of trigonometric functions and identities
  • Familiarity with equilibrium conditions in physics
  • Ability to resolve vector components in two dimensions
  • Review the concept of equilibrium in static systems
  • Learn how to resolve forces using trigonometric identities
  • Study examples of tension calculations in similar problems
  • Explore the implications of changing mass on tension in a system
Students studying physics, particularly those focusing on mechanics and tension in static systems, as well as educators seeking to clarify concepts related to forces and equilibrium.
dolerka
A ball of mass 0.850 kg is dangling as shown. The angle created with String 1 and ceiling is 30 degrees. The angle created with the second and the ceiling is 45 degrees. What is the tension in each string?
F=ma
T1=tension in string 1
T2=tension in string 2
W=weight of ball
I determined the the x and y acceleration to be zero. T1y+T2y=0. and T1x+T2x+W=0. i then used trigonometric identities.
T1y=T1sin(120)
T2y=T2sin(45)
T1x=T1cos(120)
T2x=T2cos(45)
W=8.33N
i then did substitution with the formulas and i found the tension in string 1 to be 6.10 i know this to be correct. and substituting in for the second tension i get 4.31 but i am being told that this is wrong so what exactly am i doing wrong?
W=weight of ball
T1y=T1sin(120)
T2y=T2sin(45)
T1x=T1cos(120)
T2x=T2cos(45)
W=8.33N
Suppose, for an experiment, the ball was substituted with one of twice the weight. What would be the tension in the strings?
welcome to pf!
hi dolerka! welcome to pf! :smile:
(have a degree: ° and try using the X2 icon just above the Reply box :wink:)
T1y=T1sin(120)
T2y=T2sin(45)
T1x=T1cos(120)
T2x=T2cos(45)
W=8.33N
if y is up, then your W is in the wrong equation :redface:
and whyever are you using 120° ? :confused:
(have a degree: ° and try using the X2 icon just above the Reply box :wink:)if y is up, then your W is in the wrong equation :redface:
bleh yes first time post. and the equation read T1y+T2y=0 should be T1x+T2x=0. and T1x+T2x+W=0 should be T1y+T2y+W=0. also i used 120o only because my book gives an example of a similar problem and also does this but that example on solved for one side.
the system is in equilibrium.
draw components of both the tensions...we get
T2sin30+T1sin45=ma...1
T2cos30=T1cos 45 ...2
solve de 2 eq. to get T1 and t2...please correct me...if i m wrong...i m new here!
welcome to pf!
hi Kartikc! welcome to pf! :wink:
(try using the X2 icon just above the Reply box :wink:)
yes, that looks fine :smile:
(with "mg" of course)
37K
