Simple Harmonic Motion Equation Question
In summary: NOTE: I tried it in degrees to, converted 1.76 to 101, and it still says I have the wrong answer=3.2 secs).The problem asks me to find the min/max distances from equlibrium after t=0The equation is correct. The problem asks for the maximum and minimum distances from equilibrium after t=0.
meganw
97
HELP-SEE LAST POST-I HAVE NO IDEA WHY THIS IS WRONG (SEE LAST POST)
A spring with spring constant 230 N/m vibrates with an amplitude of 12.0 cm when 0.380 kg hangs from it.
(a) What is the equation describing this motion as a function of time? Assume the mass passes through the equilibrium point, toward positive x (upward), at t = 0.120 s.
x = A cos(omega t + phi)
A = 12 cm
W = 24.6 s^-1
Phase Shift (phi)= ___________
(b) At what times will the spring have its maximum and minimum lengths? (Consider only the first instances after t = 0.)
_____________maximum s
_____________minimum s
(c) What is the displacement at t = 0?
_____________
(d) What is the force exerted by the spring at t = 0?
____________
(e) What is the maximum speed?
_____________
When is it first reached after t = 0?
_____________
[tex]\sqrt{k/m}[/tex]
Okay, so I've been working on this problem, and I got the first two parts pretty much no problem. A was practically given to you, and W was found using the formula [tex]\sqrt{k/m}[/tex]. No problems there-I've bolded the two answers that I have correct.
Now, the next part is what really gets me. If I plug everything into find phi, (the phase shift) for part a, the third answer, I don't know the x, and I don't know how to find it.
Thank you so much for the help! :smile:
you should be able to find your x and your t from this statement for starters. remember that x is the position of the mass with respect to the equilibruim position.
First-thanks for the reply!
Now I tried that, but it says my answer is wrong.
I set the equation equal to zero, since that's the distance from equilibrium:note: 2.952 is 24.6*.120
0=12cos(2.952+phase shift)
My graphing calculator has a zero at 87.04 degrees, divide that by 57.3 for the radian conversion, and I get 1.52 radians, which it says is wrong. I'm sorry,-what am I doing wrong?
hmmm, your calculator seems to be giving an incorrect answer. the next zero should occur when the argument of the cosine function is equal to 3pi/2, and you can derive the phase shift from that. (this zero also is acceptable for the question since it is also increasing at this point).
its good to learn how to do these problems without a calculator, so you can easily check your answer, since calculators can often be unreliable due to the restrictions on the range of the inverse trig functions.
Wait, derive the phase shift? What do you mean by "derive" the phase shift? Is my equation correct??
Sorry, i use the word derive too often, lol. I mean, simply calculate.
I really don't understand this at all. I'm so sorry-but could you walk me through the steps?
(by the way I put in 3pi/2 for the phase shift and it said that was wrong)
You know x, you know A, you know omega, and you know t. You can find the phase shift using the SHM formula of that wave function.
I did that, but I still got the wrong answer it says, assuming I have the correct (?) Equation:
phase shift=87.04 degrees, divide that by 57.3 for the radian conversion, and I get 1.52 radians
wrong , according to my webassign. :(
I let
x=0
A=12
W=24.6
T=.120
I'm sorry, I think I will be able to fly through the rest of the parts of this problem once I can get this equation finally. Thanks again. :)
The equation is very much correct.
arccos(0) = 2.952 + phi
pi/2 or 3pi/2 = 2.952 + phi
Now can you see why the value on the left of the equation should be 3pi/2 rather than pi/2 (what's different about the cosine function at these points?)
Why wasn't I getting that answer? Thats so weird. I had my calculator in degrees-I wonder if that was making a difference? THANK YOU! =)
Wait, I tried to find the maximum and minimum and I got that answer wrong.
Isn't there a minimum at x=.056 seconds
If I'm in radians...I get a minimum at x=.056secs with this equation:
x=12cos(24.6x+1.76)
What's wrong with this??
x=12cos(24.6x+1.76)
1. What is simple harmonic motion?
Simple harmonic motion is a type of periodic motion in which an object moves back and forth in a regular pattern. This motion is characterized by a restoring force that is directly proportional to the displacement of the object from its equilibrium position.
2. What is the equation for simple harmonic motion?
The equation for simple harmonic motion is x(t) = A cos(ωt + φ), where x is the displacement of the object, A is the amplitude, ω is the angular frequency, and φ is the phase angle.
3. How is the period of simple harmonic motion related to its frequency?
The period of simple harmonic motion (T) is inversely proportional to its frequency (f). This means that as the frequency increases, the period decreases, and vice versa. The relationship can be expressed as T = 1/f.
4. What is the significance of the amplitude in simple harmonic motion?
The amplitude in simple harmonic motion represents the maximum displacement of the object from its equilibrium position. It is directly related to the energy of the system, with larger amplitudes corresponding to higher energies.
5. How is simple harmonic motion applied in real-life situations?
Simple harmonic motion can be observed in various real-life situations, such as the motion of a pendulum, the vibration of a guitar string, and the movement of a spring. It is also used in the design of structures like bridges and buildings to ensure their stability and resilience against external forces.
