Can a Bleed Line Improve Air Removal in Hydraulic Circuits?
  • Thread starter Thread starter prickerbush
    Circuits Hydraulic
The discussion centers on the effectiveness of implementing a bleed line in hydraulic circuits to facilitate air removal. Marc, who designed a hydraulic system for research, inquired about the feasibility of adding a bleed line to improve air evacuation. Experienced users confirmed that placing a bleed line at the highest point of air accumulation, typically in a vertically mounted cylinder, can enhance air removal. They also noted that cycling the system can naturally purge air, especially in systems with an open tank configuration.
  • Understanding of hydraulic circuit design principles
  • Familiarity with hydraulic system components and configurations
  • Knowledge of pressure dynamics in hydraulic systems
  • Experience with air removal techniques in hydraulic applications
  • Research the design and implementation of bleed lines in hydraulic systems
  • Explore methods for air removal in hydraulic circuits, focusing on cycling techniques
  • Study the effects of pressure dynamics on hydraulic performance
  • Learn about best practices for configuring hydraulic systems with open tanks
Hydraulic engineers, system designers, and technicians involved in the design and maintenance of hydraulic circuits, particularly those seeking to optimize air removal processes.
prickerbush
Hey all,
I never studied hydraulic circuits but I needed to design/make a hydraulic system for some research equipment. The system (in the attached schematic) has been hooked up and used for 6 months or so. However, I think we went the hard way on with getting the air out (we had no idea what we were doing.
Anyways, my question is can I put a bleed line on this system to help with getting the air out. Never mind if the symbols are drawn incorrectly as this is pretty much just a general schematic for what we have done. If it helps, the max pressure we will ever run in the system is about 2000 psi.
Thanks for the help!
-Marc
A system should have a place where air naturally accumulates. If the cylinder is mounted vertically, that would be the place. Put the air bleed there. If in a simple system you have no such point, then don't worry about it. The air will wash back to tank and automatically purge itself from the system.
Great. Thank you. I will try what you said.
The only way I have ever had to bleed a hydraulic injection moulding machine circuit is by cycling it. Over a few hundred cycles it does makes its way out. They all have an open tank as in your diagram.
Take care though - hydraulic oil compresses the air until stiction is suddenly overcome and then the cylinders jump - too far sometimes! That much air is usually gone after a dozen cycles or so and it behaves better after that.
  • · Replies 18 ·
  • · Replies 129 ·
82K
  • · Replies 39 ·
15K
