Simple Pseudocode: Test Cases for X & Y
  • Thread starter Thread starter Hooke's Law
11 replies · 4K views
Hooke's Law
Pseudocode:
if ( x is greater than y )
then return "hello"
else if ( x is less than y + 3 )
then return "bye"
What is the least number of different test cases that I would use to test this coude(eg. What would you use as values for x and y to fully test this piece of code?
I'm thinking [ x = 0 ; y = 0 ] & [ x = 4 ; y = 0 ] , . But I'm confused with what's the "least number of different test cases".
thanks
on Phys.org
Hooke's Law said:
Pseudocode:
then return "hello"
then return "bye"
Let's simplify things a bit, and suppose that y = 0.
Code:
if (x > 0)
  return "hello"
else if (x < 3)
  return "bye"
Under what conditions would "hello" be returned? Under what conditions would "bye" be returned? Are there any conditions in which nothing would be returned?
"hello" would be returned if x = 1,2,3,4...
"bye" would be returned if x = ...-2,-3,-1,0,1, & 2
There are no conditions when nothing is returned.
If x is any positive number, not just integers, "hello" is returned.
If x is any negative number or zero, "bye" is returned.
"bye" is NOT returned if x is any number between 0 and 3.
EDIT: Ok. I get why bye is not returned with any number between 0 and 3. So what's next?
To find out the least number of test cases you can construct a Venn Diagram of each number range associated with each case. Then just pull a random number from each.
If you recall I simplified the problem by setting y to 0. Now that you understand the code with y == 0, can you understand the original code?
What do you mean by "each number range associated with each case"?
1) Pick a number, say y = 10
case 1 (explicitly)
x>y
if x = 11, 12,13 or 14...
return 'hello'
case 2 (explicitly)
else if x<(10+3)
i.e. x = 12, 11, 10, 9, 8, 7..
return 'bye'
Now combine cases to get a range(sorta like a Venn Diagram - this is my mental picture)
'hello' is returned for all x == 11, 12,13 or 14...
'bye' is only returned for all x == 10, 9, 8, 7..
As you can see the statement 'elseif x<(10+3)' is only active for all numbers less than 11 since case 1 (x>10) is satisfied first, from 11 onwards no matter what.
Is that what Mark44 meant by combining cases? But I still can't see how to get the least number of cases.
Do I need to pick other numbers for x and y? Could someone please explain to me what ""least number of different test cases" means? Is it having various numbers for x and y and finding the similar number in them?
"Least number of test cases" means the smallest number of values of x and y that are needed to exercise each branch in the code.
Going back to the simplified example I gave, where I set y to 0 -
Code:
if (x > 0)
  return "hello"
else if (x < 3)
  return "bye"
If x is in the interval (0, infinity), the code returns the string "hello". Otherwise (if x is in the interval (-infinity, 0], the code returns the string "bye". There are two test cases here. Two values that can be used are x = .5 and x = -1.
Note that the comparison x < 3 in the else clause is a red herring. If x <= 0 it will automatically be less than 3. If x is positive and less than 3, the first branch is chosen (resulting in "hello" being returned) because x is positive. Being less than 3 or greater than 3 doesn't enter into things.
Now, can you apply this reasoning to your original problem?
