Solve for Real x: (x^2-6x+9)^(x^2-4)=1 | College Entrance Exam Sample Question
  • Thread starter Thread starter Vagrant
    Quadratic
The equation (x^2-6x+9)^(x^2-4)=1 can be solved by recognizing that the expression equals 1 when the exponent is zero or the base equals one. The solutions derived include x=2 and x=4 from setting the base equal to 1, and x=-2 and x=2 from setting the exponent to zero. Therefore, the complete set of solutions is x=-2, 2, and 4. Understanding that anything raised to the zero power equals one is crucial in solving this equation.
Vagrant
Solve for all real x: (x^2-6x+9)^(x^2-4)=1
I raised both sides by 1/x^2-4, so got x^2-6x+9=1, solved it to get x=2,4.
It's a question from a college enterance exam sample paper, so I wondered if it could be that simple. Is my Solution correct?
I'm assuming you didn't mean to put '^' between the two factors. In which case just remember a*b=0 if and only if a=0 or b=0.
It's x^2-6x+9 riased to the power x^2-4
What's (x^2-6x+9)^0 ?
1. How will that help?
anything to power 0 is 1
so? Ho is it relevant to the ques?
Well anything raised to the 0 power is going to equal 1. So, how would you get (x^2-6x+9)^{x^2- 4} to be (x^2-6x+9)^0?
OK I get your point. x=2,-2. But what is wrong with my solution?
Well then if you can turn the exponent to 0, then wouldn't the equation also be satisfied when x=-2? (You already have 2 as a solution) Do you see what I'm getting at?
If you don't, graph the equation (x^2-6x+9)^(x^2-4)-1=0 and look at the x-intercepts.
Ok if I take log on both sides then I get (x^2-4)log(x^2-6x+9)=log1=0.
then i get x^2-4=0, for which i get x=2,-2 or x^2-6x+9=1 for which i get x=2,4. so is the answer x=2,-2 or x=2,4?
Not quite, the answer is going to be x=-2,2,4.
Why not or?
I couldn't graph the func. still haven't learned enough.
It's going to be x=-2,2,4 because if x=-2 or 2 then the exponent becomes 0, and anything raised to the 0 power will equal 1. x=4 is a solution because:
(x^2-6x+9)^{x^2- 4}=1
((x^2-6x+9)^{x^2- 4})^{1/x^2- 4}=1^{1/x^2- 4}
x^2-6x+9=1
(x-2)(x-4)=0
x=2,4
So, 4 is also a solution
Its simple. You get 1 on RHS iff the exponent is 0 OR/AND the base is itself 1.
So, \ x^2-6x-9=1 \ \mbox{OR/AND} \ x^2-4=0
Thanks for the help.
  • · Replies 16 ·
