Simple Task Solutions: Print Textbox and Replace Letters
  • Thread starter i try
    Hello
6 replies · 2K views · last reply
i try
I need help in solving the two simple task, and I will be very grateful if you helped me.
1)Write a program that prints the textbox:
12321
1234321
123454321
2) Write a program that brings the input sentence.In this sentence instead of the letter A there is the letter X and show theat into the newly obtained string.
Thanks a lot!
12321
1234321
123454321
Thanks a lot!
Hey i try and welcome to the forums.
Can you show us any code you've written along with any of your thoughts and what you've tried and thought about trying?
I tried to do that, but we do not succeed.
here code:
Public Class Form1
Dim m(10) As Char
Dim i, j, pr As Integer
Dim unos As Char
Dim postoji As Boolean
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Do While i < 11
postoji = False
unos = InputBox("unesi nesto")
ListBox1.Items.Add(unos)
For j = 1 To i - 1
If unos = m(j) Then
postoji = True
pr = j
End If
Next
Loop
If Not (postoji) Then
m(i) = unos
i = i + 1
i = i - 1
End If
I'm going to put your code in the tags first.
To do this you use the CODE tag with the square braces with /CODE at the end.
Code:
Public Class Form1
    Dim m(10) As Char
    Dim unos As Char
    Dim postoji As Boolean    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Do While i < 11
            postoji = False
            ListBox1.Items.Add(unos)            For j = 1 To i - 1
                If unos = m(j) Then
                    postoji = True
                    pr = j
                End If
            Next
        Loop
            m(i) = unos
            i = i + 1
            i = i - 1
        End If
End Form1
Is this Python?
OK, let's take it from the top.
The first thing you should realize that for creating the string is that you should decompose your string creation into just one routine that creates the string for the textbook (using an actual string object) and then assign this string to the value of the textbook.
For this function we should give the number of lines we want to create and then pass that to a function. Since this is a small routine, I'll write the routine and get your take on it.
Code:
Sub CalculateString(String s, ByVal n As Integer)
   s = ""
   dim x as integer
   dim i as integer
   for x = 1 to n
        for i = 1 to x
           s = s + Trim(Str(x))
        end for
        for i = x-1 to 1
        end for
        s = s + VbCrLf
   end for
End Sub
I'm assuming that you pass the string by reference instead of by value and you could turn this into a function if you want to.
