Is U+V Open in a Topological Vector Space?
  • Thread starter Thread starter r4nd0m
    Topological
In a topological vector space X, the problem at hand is to prove that the sum of two open sets U and V, denoted U+V, is also open. The continuity of addition in topological vector spaces suggests that if V is open, then the set u+V, defined as {u+v | v ∈ V}, is open for all vectors u. This implies that the sum U+V can be shown to be open by demonstrating that the addition operation preserves openness. The discussion emphasizes that proving this property for one open set is sufficient to establish the openness of the sum. Ultimately, the continuity of addition is central to solving the problem.
r4nd0m
I'm really stuck on this simple problem: Let X be a topological vector space and U, V are open sets in X. Prove that U+V is open.
It should be a direct consequence of the continuity of addition in topological vector spaces. But continuity states that the f^{-1}(V) is open whenever V is open, but not the converse. It would work if I showed that adding a constant is a homeomorphism, but I don't think this is the way I should do it. Is there any more simple way, that I overlooked?
In fact it is sufficient to assume the other one of the sets to be open. Suppose V is open. If you succeed in proving that for all vectors u the set
<br /> u+V = \{u+v\;|\;v\in V\}<br />
is open, then you are almost done.
  • · Replies 43 ·
