Simplify complex number expression into acos(wt+x)
7 replies · 4K views · last reply
DryRun
I could not type it here, so i made a screenshot and posted it below.
it's about complex numbers undergraduate level. I'm currently doing Euler's formula and De Moivre's theorem, although I'm not sure that the solution lies there.
i tried doing it by adding the values inside the cos() but when verifying via calculator with a dummy data, it didn't add up.
hi sharks! :smile:
try expaning each cos into the form Acos100t + Bsin100t :wink:
Hi tiny-tim, thanks for your time to help me out. :smile:
OK, i did the expansion and got this:
(5cos25-3cos38+7cos40)cos100t + (-5sin25+3sin38-7sin40)sin100t.
It's in the form that you said above. But then I'm stuck again. How to get the answer in the final form?
use the same Acos100t + Bsin100t formula backwards! :wink:
(btw, i think your 3sin38° may have the wrong sign)
I tripled-checked and the expansion is correct, as:
-3cos(100t-38) = -3(cos100tcos38 - sin100tsin38)
So, (5cos25-3cos38+7cos40)cos100t + (-5sin25+3sin38-7sin40)sin100t becomes:
7.5298cos100t - 4.7656sin100t
I'm not sure if i did right by simplifying it with a calculator. Or maybe i should have kept the answer in cosine form?
By dividing each term:
1.580(cos100t - sin100t)
But i can't figure out about cos (alpha) for the final form.
I expanded the term Acos(wt+x) (i'm using x as i can't figure out how to type the alpha symbol here).
And got this:
Acosxcoswt - Asinxsinwt
no, you do need it in this form
that's not true :confused:
you need to write 7.5298cos100t - 4.7656sin100t in the form (Acos100t - Bsin100t)C :wink:
But doing that makes it no longer equal to the original expression.
And got this:
Think about this:
[tex]A\cos(t) + B\sin(t) =\sqrt{A^2+B^2}\left(\frac A {\sqrt{A^2+B^2}}\cos(t)<br /> + \frac B {\sqrt{A^2+B^2}}\sin(t)\right)[/tex]
where those two fractions can be a sine and cosine of some angle since the sum of their squares is 1.
OK... Then, using LCKurtz's equation above, i get:
8.9112(0.8449cos100t - 0.5348sin100t)
I need the values 0.8449 and 0.5348 to be cosx and sinx respectively.
So, i used arc cos and arc sin and got the answer, with alpha = 32.33 degrees in both.
The answer is: 8.91cos(100t+32.33)
I think it's finally solved now.
Thanks to both of you. :smile:
On another note, is there any other way to solve this? By using complex numbers? I mean, Euler, DeMoivre, etc? Just wondering.
OK, i figured out an easier way of doing it:
By comparing coefficients of coswt and sinwt.
