Simplifying 2^3 / 2^0 - 2^-1 with exponent laws
  • Thread starter Thread starter Nelo
    Exponent Laws
9 replies · 3K views · last reply
Nelo
2^3 / 2^0 -2^-1
solving using exponent laws
i move the negetive one over and make it 2^3 /2^0 = 1/2^1
I get 8 on the left side, and 2 on the right, bring the 6 from the right to the left and get 2. The answer is 16, i don't know how to get it. Anyone?
2^3 / 2^0 -2^-1
Is that:
[tex]\frac{2^3}{2^{0}-2^{-1}}[/tex] ?
QuarkCharmer said:
2^3 / 2^0 -2^-1
Is that:
Yes because the answer is 16 :)
[tex]\frac{2^3}{2^0}- 2^{-1}= \frac{8}{1}- \frac{1}{2}= 8- \frac{1}{2}= \frac{15}{2}[/tex]
[tex]\frac{2^3}{2^0- 2^{-1}}= \frac{8}{1-\frac{1}{2}}= \frac{8}{\frac{1}{2}}= 16[/tex]
How do you solve this problem?
3^g+3 - 3^g+2 = 1458
Ive been stuck on it for a whole hour
There is no solution. You write 3^g+3 - 3^g+2, which means (3^g) + 3 - (3^g) + 2, and this is equal to 5. If you actually mean something different, USE BRACKETS. For example, maybe you mean 3^(g+3) - 3^(g+2) = 1458. Of course, that would have a solution, which we could get quite easily using the fact that 3^(g+3) = 3*3^(g+2).
RGV
there's no brackets, and there is a solution , its 4.
Heres another one.
-500 = 5^y+1 -5^y+2
looks like the same type of problem, answer to this ones 3
You seem to be missing a VERY IMPORTANT point: you *must* use brackets because otherwise what you are writing is in violation of all standard math writing rules. People will automatically assume you mean what you write, but apparently that is not true!
RGV
Here's another one.
-500 = 5^y+1 - 5^y+2
If you mean that y+1 and y+2 are exponents, then you should (must, actually) use parentheses or other grouping symbols to indicate where the exponent ends and the rest of the expression picks up again.
I assume you meant:
-500 = 5^(y+1) - 5^(y+2) .
It works even better to use the X2 button above the advanced version of the reply box. Then you don't need the parentheses. This gives:
-500 = 5y+1 - 5y+2
To solve this, notice that 5y+2 = (5)(5y+1)
Factor (5y+1) out of 5y+1 - (5)(5y+1).
The answer is y = 2.
