Simplifying g(r s t) = r't' + rs' + rs with K-maps
  • Thread starter Aristotle
    Product Sum
1 reply · 3K views · last reply
Aristotle
Figure out the minimum sum of products for g(r s t) = r't' + rs' +rs
2. The attempt at a solution
I understand you can simplify it with the Boolean theorems (e.g r't' + r = t' + r) , however how would you solve it using K-maps? I drew out a truth table, but it seems as if this SOP expression is simplified to the point where there is a missing variable for each term in the function to be able to plot the minterm within the k-map..
How would I go about in approaching this problem using k-maps?
Fill out the K-map:
Handwritten 3-variable Karnaugh map with S T column headings 00, 01, 11, 10 and R row labels; top row reads 1, 0, 0, 1 and bottom row reads 1, 1, 1, 1. Below it is written G = T' + R.
The lower four 1's will give R. The leftmost/rightmost four 1's will give T'. Thus G = R ∨ T'.
