Simplifying this trig solution
  • Thread starter Thread starter jhahler
    Simplifying Trig
The expression csc(x)sqrt(sec^2(x)-1) can be simplified using the Pythagorean identity 1 + tan^2(x) = sec^2(x). By substituting this identity, the expression simplifies to csc(x)tan(x). This further simplifies to 1/cos(x), which equals sec(x). The restriction of 0 ≤ x < π/2 ensures that all trigonometric functions are non-negative, allowing the square root to be simplified without ambiguity. The final simplified expression is sec(x).
jhahler
Simplify this expression: csc(x)sqrt(sec^2(x)-1) with 0 less than or equal x less than pi/2.
Not really sure what they want here, but would a good place to start be to square the entire expression to get rid of the square root or would that make things more complicated? and what is meant by x being between 0 and pi/2?
Squaring the expression is not recommended.
Do you know a trig identity relating tan2(x) and sec2(x) ?
Use that.
gotcha, the Pythagorean identity 1+tan^2(x)=sec^2(x)
ok, I think I got this if anyone wants to confirm, still not sure about the x greater or equal to 0 and less than or equal to pi/2, but here goes. csc(x)sqrt(sec^2(x)-1) turns into csc(x)sqrt(tan^2(x)+1-1) after the Pythagorean identity, then simplifies to csc(x)tan(x) after you do the square root. csc(x)tan(x) is equal to 1/sin(x) * 1/cos(x), those multiply together to give 1/cos(x) and that equals sec(x), that sound right?
I think you mean \frac{1}{sinx}\times\frac{sinx}{cosx}.
But yes, that looks right.
The restriction: 0 ≤ x < π/2 means that all of the trig functions give a non-negative result and in particular, \sqrt{\tan^2(x)=\tan(x)} without the ± sign.
yes, bread18, i did mean \frac{sinx}{\cos(x)}
Thanks by the way!
